Help me pick a distributor
I don't know which one I need. I am going with MSD but wasn't sure if I should get mechanical advance or vacuum.
I am building a 468 ci motor for my truck. This truck is going to just be a weekend type toy. Not a daily driver. I am going with a Comp Cams XE274H cam. If is fairly choppy so I didn't know if a vacuum advance would be right for me. I found a 6AL Ignition box and an MSD pro-billet distributor with mech advance for a pretty good price. I started to jump on them but I thought I better ask you guys first. Thanks for the help guys!!! |
Re: Help me pick a distributor
Pertronix igniter III has the Rev limiter and the multi spark (through the entire RPM range) built into the distributor cap all for about $230. I love mine.
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() |
So should I stick with vacuum advance for something I am driving on the street?
The distributor will have both vacuum and mechanical advance . You need mechanical advance unless you plan on running a retard box and a bunch of other electronics. Any distributor will have mechanical advance.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
OK, then should I run a mech/vacuum advance or mechanical only.
Run both the vac advance will help clean things up at cruise rpm
#8 | |
I'm probably not much help but I went with a msd 6al box and msd pro billet distributor on my mild 496. I havn't ran this set-up yet as I am still in the build process.
#10 | |
Wanted to bump this again to see if anyone had any experience with the street/strip version of this DUI distributor. |
I have not read anything bad about DUI dist. In fact, i have seen them used by a lot of Engine builders, David Vizzard as one. He swares by them. But, no rev limiter or multi spark, just a bigger spark.
You can order a built in rev limiter for them. What is multispark?
Posted via Mobile Device |
Built in as in non adjustable? Its fine. A multi spark means you have up to 3 sparks on each cylinder per stroke. The MSD series has 3 up to 3000rpm's. The Pertronix has 2-3 depending on rpm through the entire rpm range. This creates a much better/efficient burn which in turn makes more power.
#14 | |
Is this the one you have? http://www.summitracing.com/parts/PNX-D7100710/ I am assuming it has a place to hook up a tach? How do you adjust the rev-limiter? Any special plug wires or plugs I should run with it? What is a Hall Effect trigger style as oppose to magnetic? Last edited by baclay9; 11-26-2010 at 10:08 AM. |
#15 | |
69 c-10 BBC ![]() 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles. ![]() Last edited by ripdog28; 11-26-2010 at 08:41 PM. |
#16 |
Thanks for the advice Ripdog28, I think I will give the Pertronix a try. It sound pretty good to me and I like the price. I just read through your build thread. I like your truck man. I hope mine is making somewhere close to as much power as yours when I get it together.
#17 | |
