Old 12-13-2010, 03:53 PM   #1
Clyde65
Clyde65's Avatar
72 c10 Rear Dif gear options
I have a 72 C10 12bolt rearend under my 65, I had it rebuilt a year or so ago and stuck with the 3.08 gears, what can i put in there without changing the housing? 3.42\3.73?
Thanks guys.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 12-13-2010, 04:08 PM   #2
GobbleStalker
GobbleStalker Calls
GobbleStalker's Avatar
Re: 72 c10 Rear Dif gear options
I think you can do both. Check with Randy's Ring & Pinion.
72 Chev Longbox Highlander edition. Med Olive/White/ Med Olive 350 4bbl with 350Turbo trans. Truck currently under construction. Project Cappaccino.
Stay Tuned!
1967 Chevy C10, 327, 4.11 posi 3 spd. The Driver Truck! SOLD!
09 GMC Sierra SLT All Terrain pkg.
2014 Jeep Wrangler Sahara unlimited. ( The wifes ride )
GobbleStalker is offline   Reply With Quote
Old 12-13-2010, 04:11 PM   #3
allengator
allengator's Avatar
It is my understanding that 3.xx gears will all go into the same housing...
Allengator
Outta the Blue
(my band - available for hire in the DFW area!)
1980 Chevy SWB Pickup (build thread)
1951 Chevy Sedan Delivery
2004 Chevy Tahoe Z71
2011 Harley Davidson Street Glide
2018 Silverado Z71 Crew Cab
allengator is offline   Reply With Quote
Old 12-13-2010, 04:18 PM   #4
raycow
You can put any 12 bolt gears in the housing. However, if you want to keep your present differential case you can use OE type gears only up to 3.42. For anything numerically higher you have to use a special aftermarket gear set with a "thick" ring gear or a ring gear spacer, which some people advise against. I am neutral on the spacer.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
