Old 12-14-2010, 12:27 AM   #1
akeane01
1955 C3100 1st series
I have a question for the board. Attached is a picture from the truck i bought. I am wondering why this person cut around the outside of the radiator frame, then cut the frame in half only to weld back a piece??
I did notice that the radiator was mounted on the outside of the frame. I thought it would go inside the radiator bracket?
any comments on why this was done?
akeane01 is offline   Reply With Quote
Old 12-14-2010, 09:35 AM   #2
Russell Ashley
Russell Ashley's Avatar
Re: 1955 C3100 1st series
Part of the fun of buying an old truck, trying to figure out why some po did what they did, LOL.
I think in your case he needed a radiator and had access to one that didn't fit. Rather than spend money on fixing or replacing the original one he just made the free one fit. Generall speaking, appearance wasn't a consideration.
Russell Ashley is offline   Reply With Quote
Old 12-16-2010, 09:23 AM   #3
GRIMSS
GRIMSS's Avatar
Maybe it has the later I6 that's longer?
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 12-16-2010, 10:34 AM   #4
fosheec
fosheec's Avatar
I am guessing 235 conversion with the long water pump...
Caleb
fosheec is offline   Reply With Quote
Old 12-16-2010, 01:40 PM   #5
akeane01
hi,
I did notice the the fan does encroach into the radiator bracket...
can you tell me more about the water pump?
Old 12-16-2010, 03:52 PM   #6
RootBeer 6117
RootBeer 6117's Avatar
It looks like a crow bar in the picture, is it just hanging there?
Something I have said many times to my students;Common sense didn't play a part in your decision to do this did it?
RootBeer 6117 is offline   Reply With Quote
Old 12-17-2010, 02:22 PM   #7
fosheec
fosheec's Avatar
The 235 engine was put into the trucks in 54 and up. In its stock configuration, the water pump was longer than the original 215's...
Throw together some beer, a NEARLY identical engine with more power, and a cutting torch...and it became one of the most popular modifications for these trucks...
Caleb
Old 12-17-2010, 05:22 PM   #8
Houston54
Who knows. My guess is the cuts were made to fit a different radiator in place. The fan on these is tet tight up against the radiator so from this angle it is not possible to tell if there was an interference.
Houston54 is offline   Reply With Quote
Old 12-17-2010, 09:42 PM   #9
akeane01
Fosheec,
ok, how did radiator assembly come out of the factory then with the 235 in 54and above if it was too long?
Old 12-18-2010, 11:26 AM   #10
fosheec
fosheec's Avatar
I believe (somebody correct me on the year if I am wrong...) that the rad support design changed in 54 and up...moving the radiator out just enough.
Caleb
