Old 12-17-2010, 10:24 PM   #1
66folks
another Oklahoma find
Hi,
I just picked up a 66 GMC 1/2 ton with the 305 V6 in it. currently working on trying to get the 305 to free up and turn over but not much success as of yet. The truck has a 4 speed tranny in it (think its a munci but have cleaned all the dirt off of it). The one thing im not sure of is the rear suspension, the truck has leaf springs with helper springs. Is this a standard setup of 1/2 trucks or a special order from the factory?
66folks is offline   Reply With Quote
Old 12-17-2010, 10:34 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: another Oklahoma find
Welcome to the gang!!
Looks like a good start to a fun project. Not sure about the 66 GMC rear leafs, but the helpers are available on all of these trucks.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 12-17-2010, 11:08 PM   #3
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
!? another 66 w/ the factory buckets!
I hadn't even heard of them until last week, and now I see 2 in 2 weeks imagine that both in ok too...
dosen't look too bad for a start, but that front bumper has seen better days!:LOL:
Old 12-17-2010, 11:09 PM   #4
jonzcustomshop
1961 crewcab
for your? all gmcs 63-66 had leaf springs from 1/2 ton on up.
Old 12-17-2010, 11:24 PM   #5
463
463's Avatar
lots of good help here and a very well moderated forms. to free up the eng remove the spark plugs and add diesel replace plugs ad let it sit a day or two then try to roll the eng over by hand. i like the buddy buckets and V6. nice find.
Trueman
463 is offline   Reply With Quote
Old 12-17-2010, 11:36 PM   #6
66folks
The PO said the seats were out a 70's international, the bolt holes on the seat dont match up with the cab's bolt holes. he had the seats setting on a couple of 2x4's to get a decent height to see over the dash.
Old 12-17-2010, 11:38 PM   #7
Jonboy
Slots go on anything!
Looks like a great start
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 12-18-2010, 01:45 AM   #8
Captainfab
60-66 Nut
Welcome to the forum
Keep us posted on your progress or if you have further questions.
Old 12-18-2010, 08:30 AM   #9
duallyjams
duallyjams's Avatar
Welcome aboard
lot of good info here http://www.6066gmcguy.org/
a lot v6 engine in your area on CL
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-18-2010, 10:55 AM   #10
Stew64
Stew64's Avatar
I have a 64 GMC that came with a set of helpers mounted under the stock leafs. Looked factory but can't say for sure.
1964 Longbed
Stew64 is offline   Reply With Quote
Old 12-18-2010, 01:17 PM   #11
kieth
kieth's Avatar
Another Okie here, Tulsa, Ok I have a 66 gmc in process got it down in Texarkana......
Here is a link to my build.......Kieth (I have a spare 65 gmc cab, swb frame with spring susp and front hood and clip in case you need some parts. Kieth
918-446-2245
http://kieth.smugmug.com/Trucks/66-G...67555158_RNLWE
good luck on your build....
kieth is offline   Reply With Quote
Old 12-18-2010, 02:20 PM   #12
Bugeyev8
Bugeyev8's Avatar
by the looks of the shifter its not a munci trans, looks like the old SM..something, great truck by the way, try throwing the truck in 4th gear and rocking it, that may free up the engine, throw some atf in the cylinders or down the carb before you do
Bugeyev8 is offline   Reply With Quote
Old 12-18-2010, 02:32 PM   #13
jim8step
That looks like a nice unmolested start, can you tell what the original door lettering was?
jim8step is offline   Reply With Quote
Old 12-18-2010, 05:47 PM   #14
66folks
jim8step
From what i can read of the door is says Shawnee soil conservation and not sure what the bottom word is.
463
I have taken the heads off of the block and put some marvels down the cylinders. I am thinking of taking off the water pump and timing chain to see if that will free it up before i pull the engine out of the truck to look at the bottom end of it.
