C30 Dually Front Rotors
Does anyone know a place that carriers front dually rotors for a 71 C30? Or will one from a 73 -91 work?
![]() Join Date: Apr 2007
Re: C30 Dually Front Rotors
Haven't found any aftermarket ones. Gave up and swapped to newer 73-87 ones. Easy swap. On your 71-72 t c30 you can swap out the spindle direct bolt on. Same ball joints, same tie rod ends. Bolts right on the use the newer rotors and calipers and the flexible brake lines.i re routed my brake lines like this .
![]() Join Date: Mar 2003
I changed mine over as well. The 'newer' rotors are thicker at 1.5'' instead of 1.25
The newer setup uses the JB 8 style caliper. The newer rotor won't work with the current setup.
Not at all. I swapped everything from spindle out, went with new rotors and calipers. Had a custom brake lines made also. I did this in my 69, so I was also converting from drum
