Old 04-29-2014, 11:07 AM   #1
Grizz1963
Grizz1963's Avatar
Standard wheel arch height on a '66 Short Fleet?
Some great stance and lowering on various builds.
I have a '66 Short Fleetside which has been lowered with heated cools etc a long time ago. THREAD HERE: http://67-72chevytrucks.com/vboard/s...d.php?t=585901
The truck behaves like a rubber duck on water when doing the bends.
It is fitted with a 350/3 speed auto combo that obviously influences ride height a bit. But hope someone can measure a "standard height" V8 truck to give me a better idea of where I should be and where I should be heading.
I really like a bit of nose down rake.
Plans are to keep to standard 6 lug, drum brake setup so no dropped spindles etc. And is still needs to to my teardrop.
I am looking at replacing the shocks and springs when I repaint and strip down the truck.
Brothers currently has 50% off on the lot.
My truck parked up in the garage shows these measurements to the underside of the fenders.
Front 27 1/4
Rear 26 1/2 on passenger side
26 on driver side
Does anyone have the stock standard measurements for these truck front and rear please??
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 04-29-2014, 11:55 AM   #2
kieth
kieth's Avatar
Re: Standard wheel arch height on a '66 Short Fleet?
Hey Grizz, just order stock front and rear coils.......that should get you back to stock height.......and stock shocks....................its a no brainer....Kieth
kieth is offline   Reply With Quote
Old 04-29-2014, 02:28 PM   #3
1963c-10
1963c-10's Avatar
Measurements from the factory would depend on rim and tire size that were installed on the truck.
I agree with Keith, if you want stock height/stance just order stock springs/shocks.
1964 Short bed trailer
Old 04-29-2014, 03:59 PM   #4
Grizz1963
Grizz1963's Avatar
Not going back guys.
I want it as it stands or even a touch lower. But need an idea on original height so that I know where I am now and where to head.
Old 04-29-2014, 04:32 PM   #5
forestb
forestb's Avatar
It seams like someone on here from the most original trucks in existence thread could give you that measurement but instead I will try to help.
on a fleet side truck measuring from the bottom of the fender to the center of the hub. A 5 inch rear drop will equal 10.5 inches and in the front a 4.5 inch drop will equal 14 inches. I know this is not exactly what you wanted but hopefully it will help you calculate.
forestb is offline   Reply With Quote
Old 04-29-2014, 04:42 PM   #6
1963c-10
1963c-10's Avatar
My truck is stock stance, but I'm running a 235/75R15 which is a little taller than the factory tire. I believe a 215 would be pretty close to stock tire...I can get numbers off either my fleet or stepside. Both are stock height and run the same tires size.
