Old 12-28-2010, 02:33 PM   #1
Pyrotechnic
Pyrotechnic's Avatar
Upgrade to aluminum/plastic master cylinder
The cast iron master cylinder on my truck keeps leaking all the fluid out. The gasket is in good shape but the machined sealing surface keeps rusting for some reason.
Will the plastic/aluminum master cylinder from an 80's truck bolt in place and do the lines have the same thread? I think these look a little better and I always hated how even the littlest spill ate the paint off the cast iron one.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 12-28-2010, 02:58 PM   #2
sierra4x4
sierra4x4's Avatar
Re: Upgrade to aluminum/plastic master cylinder
IIRC the lines are the same but it will only fit if you have the booster to go along with it becouse where the fit together is different.
sierra4x4 is offline   Reply With Quote
Old 12-28-2010, 04:05 PM   #3
bitchin85
bitchin85's Avatar
on mine the lines were different sizes...
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 12-28-2010, 04:24 PM   #4
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
the lines on mine was the same but the master cylinder didnt fit the brake booster
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 12-29-2010, 02:44 PM   #5
Keith Seymore
Keith Seymore's Avatar
Make sure the lines go to the right end as well....
that is, on some cast iron units the front reservoir is for the front system and the rear supplies the rear; whereas on the aluminum/plastic the front is for the rear/ rear is for the front.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 12-29-2010, 10:26 PM   #6
bitchin85
bitchin85's Avatar
K
this is probly why mine didnt match up.. and why i didnt do it..
Old 12-29-2010, 11:38 PM   #7
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
For an 90 suburban with the plastic tanks, Raybestos makes 1", 1 1/8" and 1 1/4" bore master cylinders. Shows Ports=2 Primary Outlet Size=9/16x18 Secondary Outlet Size=1/2x20
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 12-30-2010, 12:57 PM   #8
Pyrotechnic
Thanks guys! I did notice looking through parts catalogs that the reservoir sizes looked a little odd but I guess I know why now.
What didn't match up when you guys tried to bolt up the newer MC? Was the center hole in the booster too small or was the mounting bolt spacing/location wrong?
Old 12-30-2010, 02:07 PM   #9
Keith Seymore
It's the center hole size (not the mounting stud/spacing).
Some of the aluminum master cylinders have the "quick take up" feature, which allows less drag on the front discs for better rolling resistance and improved fuel economy. These are larger in the rear where they fit into the booster.
So - you can put a "non QTU" master in any booster, but you can't put a QTU master in a "non QTU" booster.
K
1979-1986
1986 - 2019
Old 12-31-2010, 06:27 AM   #10
Pyrotechnic
Thanks Keith. I looked up part numbers for boosters and there are different part numbers for 1973-1980 and 1981+ and like you say I can see in the pictures where the hole in the later models are larger. Too bad, the booster I'm running is pretty new so it'll have to stay a long with the cast iron master cylinder. Guess I'll just order a new lid and gasket and hope it seals.
