I have a 65 c10 fleetside longbed which needs a lot of body work, i found a 64 c20 that is for sale and was thinking of buying it just for the body. Do you guys know if this will work? To me both front fenders and the bed look exactly the same. Thanks for the help in advance.
Re: Getting started on 65 c10
All the same
![]() Join Date: Mar 2013
All the same style but mind you, watch out for slight changes in bolt patterns that will cause bolts not to line up with holes. Used 64 chevy fenders on my 66 and most of the holes lined up except for almost all the grill panel holes. So if you change fenders I'd use the same grill panel as well.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Thanks guys
Tags |
c10 2wd fleetside longbed, c20 |
