Old 01-05-2011, 09:57 PM   #1
trkfrk
trkfrk's Avatar
whats different on 71,72 front suspension parts?
It seems to be harder to find parts for the 71-72 front ends ( drop spindles, upper & lower balls joints etc.) Can I use 67-70 parts?
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 01-06-2011, 11:04 AM   #2
flashed
Re: whats different on 71,72 front suspension parts?
ttt for you .
flashed is offline   Reply With Quote
Old 01-06-2011, 11:34 AM   #3
JimKshortstep4x4
Upper ball joints, tie rod ends, and drag link are different.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-06-2011, 11:45 AM   #4
OhOneWS6
OhOneWS6's Avatar
I've had no issue finding those parts for 71-72. From local auto parts to board vendors, they seem to all have those parts in stock and readily available. Only difference being brand and quality between sources.
OhOneWS6 is offline   Reply With Quote
Old 01-06-2011, 03:56 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
What exactly are you trying to do?
Also,... what year truck are you working on?
Keith
Convert to disc brakes.
Old 01-06-2011, 06:20 PM   #6
71 super
71 super's Avatar
Lowerball joints are different as well. If you are swapping from 67-70 to 71-72, you will need the following parts: Upper and lower ball joints for 71-72, inner and outer tie rods and sleeves for 71-72, drag link for 71-72, spindles for 71-72. Parts you can reuse: pitman arm, end link on pasenger side. Hope this helps, just did a swap on 68 from drum to disk and used the rotor/caliper line kit from GMC pauls- $350 +/-. you will need to buy a reman 71-72 disk brake master cylinder $25 and a prop valve either used or on ebay for roughly $50. You will need to buy a pair of adapter bushings to reduce the upper lines from 1/4 to 5/16 at bottom of prop valve, you will also need a 1/4 to 1/4 compression fitting and a 8" length of steel line that is 1/4 to the correct end (size escapes me at the moment) to fit in the rear of the prop valve. With replacing ball joints and bleeding/install figure a good sat. or roughly 5 hours. It is a 1 man job until the bleeding of the brakes. It is pretty straight forward and the kit from GMC pauls uses good components, wheel bearings, seals, calipers, hoses and pads. Easy to do, just dont rush. Hope this helps.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
