Old 01-17-2011, 11:30 PM   #1
yellowdawg
350 to 700r4
I want to change my 350 for a 700r4. Im 4x4 and am wondering if I swap trans will my original driveshafts still fit or do i need to lethen and shorten them. I Plan on using my 205. thanks
yellowdawg is offline   Reply With Quote
Old 01-18-2011, 12:18 AM   #2
sierra4x4
sierra4x4's Avatar
Re: 350 to 700r4
You will need to change them. If your putting a 700r4 in you will either need the special 205 output shaft or you can use a spacer between the trans and t-case. Either way you go the new combo will be longer than your current set up.
sierra4x4 is offline   Reply With Quote
Old 01-18-2011, 12:28 AM   #3
1959 Apache
Re: 350 to 700r4
The 700R4 (4L60) is 3" longer than the TH350 trans. If you use the same t-case and adapter you will need to shorten the rear and lengthen the front shaft 3" each.
Dave W.
1959 Apache is offline   Reply With Quote
Old 01-18-2011, 12:35 AM   #4
D O C
Re: 350 to 700r4
you can get a fits all adapter and cut a 1/4" off the 700r4 shaft
D O C is offline   Reply With Quote
Old 01-18-2011, 12:52 AM   #5
67swb72klb
67swb72klb's Avatar
Re: 350 to 700r4
there are other threads on this do a search think u can move the motor up 1 3/4 & not cut anything
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 01-18-2011, 02:04 AM   #6
KrazyRay
KrazyRay's Avatar
Re: 350 to 700r4
x2
KrazyRay is offline   Reply With Quote
Old 01-18-2011, 10:32 PM   #7
BERT306
BERT306's Avatar
Re: 350 to 700r4
x3
72 k10 swb. 350/th350/np205. Vintage air'd daily driver
BERT306 is offline   Reply With Quote
