It cranked right up Tuesday but wont crank now. I tried charging the battery that didn't work. I put gas in the carb and nuthin, I looked in the plugs and nuthin, Please somebody help..
![]() Join Date: Apr 2004
Re: it just won't turn over
if it doesn't crank, all the gas in the world will not help. If you know the battery is good, check the connections at the battery and the starter. Do you hear any clicks or anything at all. Do you have a DMM? If not, you should buy one. It can make electrical troubleshooting much easier.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
The starter connection is good, it tries to crank but no cigar
71 ![]() |
What do you mean it tries to crank? Will the engine turn over when you turn the key? Or will it do nothing when you turn the key?
-Scott- |
not turn over means that the engine does not rotate
or do you mean the engine turns over and does not start
sorry.. turns over but does not start.
Air,fuel,fire. Are you getting any spark?
Ain't no way in the world I'm going out that front door. 69 SWB Fleetside 327/5spd 76 blazer 383/700R4 95 2Dr Tahoe 5.7 4x4 LT |
I took a plug wire off and saw spark. It has fuel, and as for air it's cold as all get out here.
if you have points check them and make sure there is a good spark. keep it simple air fuel and spark if it just ran the other day it should be close to running again I would think.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
Are you getting 12 Volts to the Dist? What color is the spark? Blue or orange?
How would I check to see if the distributer was getting 12 volts? My boss said it probably just had moisture in the distributer cap, any thoughts?
71 ![]() |
So i just took the distributer, cap off and it was dry.....
if you have points i'd clean and gap them to proper specs// .019gap or dwell of 28-32degrees
The previous owner converted it to electronic ignition. Ignition is definitely not my thing.... YET
#15 |
What?
Did it run before the electronic ignition was installed?
If not, then make sure it is clocked correctly and the plug wires are in the proper firing order. Everyone does this differently it seems, but for me I make sure the engine is at TDC compression stroke. Then pop the distributor cap, the rotor terminal should point to the #1 cylinder and the cap terminal that the #1 wire is plugged onto. If it ran and drove fine after the electronic distributor was installed, what if anything has changed since then? Power brakes? If so, check the power booster hose to the intake manifold. If it has come off or cracked open, it will be a huge vacuum leak that can hinder a cold start. No power brakes? make sure the intake bung used for the booster is properly capped off, this includes some carburetors that will have a large opening for this vacuum source. What kind of carburetor? Choke hooked up? Do you see fuel squirting from the carb jets?
Chris 1968 K20 Suburban 1972 K10 LWB PU |
#16 |
I bought it a year ago and it was installed before then and has ran fine until now I cranked it Tuesday fine but wendsday it wouldn't, so nothing has changed,
I looked at a plug it fired a yellow orange color
71 ![]() |
#17 |
The Niner
![]() Join Date: Nov 2010
Timing chain?
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
#18 |
Its turning over fine and turning the rotor, It worked fine last time i shut it off,
Could it still be the timing chain... At this point i'm pretty much clueless
71 ![]() |
#19 |
Electric choke? If so I have had the hot wire come undone for the choke and the ***** did not want to start one cold morning. I was tearing my hair out and looked under dash and saw the choke wire undone. Plugged it in and whamo blum blum blum blum blum away we go!
#20 |
Nope Manuel choke, could it be the coil?
71 ![]() |
#21 |
![]() Join Date: Nov 2002
if it has air-fuel-spark, I would hold the gas peddle down to the floor for a couple of minutes, leave it there while you are turning it over. Maybe you're flooding out the carb.
#22 |
#23 |
Embrace the Redneck
I'm going to mention something many look over.
Take the module out of the HEI and take it to Autozone and have them test it. I bet it's went out on you. Take the coil with you and have them test it. To check the chain just pull the dist and turn it over. If the dizzy is turning then the cam is turning and the chain is turning it. It may be out of time. Check that. It sounds to me like it may be a Fire issue so keep looking there. To check for 12V at the dizzy pull the wire to it and put a voltmeter on it with the key in the ON position.
'01 Camaro Son, you just can't get there from here... Last edited by whitesswj; 01-15-2011 at 05:28 PM. Reason: Added coil |
#24 |
http://67-72chevytrucks.com/vboard/s...d.php?t=440715 go to post #8 there is a pic
Trueman |
#25 |
I tried holding the gas down for a while.
I just got back from having the module tested. I'm checking the coil now. it acts kinda of like one cylinder fires but none of the others... So cap and rotor maybe?
71 ![]() |
