Old 02-04-2011, 09:28 PM   #1
68jimmy
68jimmy's Avatar
What is this?
As the title says, what is this?
Thanks!
78 C10 LWB Super Cheyenne
68jimmy is offline   Reply With Quote
Old 02-04-2011, 09:38 PM   #2
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: What is this?
As im typing this, im sure somone else is also...
Its a heat riser valve. Vacuum is applied to the diaphragm(the big can thing with the nipple on it) and closes a butterfly valve. This forces all the exhaust gas threw the head, intake, and out the other head warming the engine up faster in cold weather. The vaccum line should be in line with a thermostatic vacuum switch that will shut vacuum off once the truck warms up and therefore, re open the butterfly valve. Between the exhaust manifold and exhaust pipe is a piece smiler to this,
thats what the diaphragm is opening via a rod that goes from the diaphragm to the butterfly valve.
y5mgisi is offline   Reply With Quote
Old 02-04-2011, 09:39 PM   #3
y5mgisi
y5mgisi's Avatar
Re: What is this?
Assembly looks a little like this.
Here is what mine looks like,
[IMG][/IMG]
Old 02-04-2011, 09:41 PM   #4
y5mgisi
y5mgisi's Avatar
Re: What is this?
another helpfull photo.
Old 02-04-2011, 10:13 PM   #5
68jimmy
68jimmy's Avatar
Re: What is this?
Thanks for the quick reply. What is the vacuum source for this valve? I did notice what appears to be a TVS on the thermostat housing with the top fitting going to the carb and the lower one being open... Can you send me some pics of your setup?
Thanks!
