Old 02-14-2011, 06:32 PM   #1
Reziel_1983
Reziel_1983's Avatar
Truck dies after going into reverse.
So I put my old quadrajet on after I put a new, bigger cam in my engine(350). We couldn't get the timing right with the edelbrock 600 cfm we had in before, so we swapped it out for the quadrajet and now it is in time. However, now whenever I shift into reverse my truck will die... it will idle REALLY low and then just die. Does my carb need to be rebuilt? I tried idling it up some... it didn't seem to help it.
1983 Chevy lwb: 400 sbc destroked to 377, comp cams xe 268, Holley Street Dominator Intake, Holley Street Avenger 670 cfm, headers, flowmasters. SOLD
1998 Trans am, mostly stock with magnaflow catback
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=454329
Reziel_1983 is offline   Reply With Quote
Old 02-14-2011, 07:02 PM   #2
Clyde65
Clyde65's Avatar
Re: Truck dies after going into reverse.
Idles low, like under 600rpm?
If so, when you shift into reverse you are putting a load on it and that might be the cause of it dying. check timing first then adj your carb settings. also what cam did you put in there?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-14-2011, 07:42 PM   #3
Reziel_1983
I'm not sure how many rpms it is getting when it idles lower. But It's LOW.
Also, not sure what the exact specs on the cam are... I can maybe get them, I'll try. Before this cam I had a Crane Cam that was I believe one step above stock. I think this new cam is 2 or 3 steps up from my old one. At first it would just idle really low after shifting into reverse but then it would catch up and it would idle higher and I could go, but now it dies almost every single time I put it into reverse, even if it's going from drive to reverse.
Old 02-15-2011, 10:58 AM   #4
Clyde65
Clyde65's Avatar
It sounds like you timing might be off or there is a vacumn leak. I say this because when you shift into Drive or reverse, the trans pulls more vacumn and the engine sees that and bumps the timing a little
Clyde65
Rebuild of Clyde
support our troops!
Old 02-17-2011, 01:54 AM   #5
mag68
mag68's Avatar
Maybe i missunderstood your problem, but you said "after installing a bigger cam". I assume you have an auto trans. You may need a higher stall torque converter. I rebuilt my 454 and it wouldnt idle in gear. I went to a 2800 stall and it worked great.
mag68 is offline   Reply With Quote
Old 02-17-2011, 10:31 AM   #6
geezer#99
geezer#99's Avatar
REcurve your dizzy. Less mechanical in the dizzy and more initial timing.
x2 on the convertor.
Old 02-17-2011, 11:07 AM   #7
spudz
spudz's Avatar
sounds like you have too big of a cam for your stock convertor.... Not my truck but I wouldnt install a cam and not know what the specs were.... Also, my experience.. stock q-jets dont work well with big cam. I;m sure they can be tuned to run just fine but I never had good luck.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
