Old 02-09-2011, 05:54 PM   #1
62 Bowtie
62 Bowtie's Avatar
lower a-arms
im almost done! with my bags not the truck I noticed my lower A-arms barely budge could this keep the truck from lifting when I hit the switch the rear moves fine when i hit the front nothin in fact the rear moves im using the vu4 and avs 7 controller triple checked wiring thanks
62 Bowtie is offline   Reply With Quote
Old 02-09-2011, 11:22 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: lower a-arms
Do you mean they are extremely tight?
(at the cross shaft bushing?)
Any or all of the front end parts new?
Or do you think you just have an electrical problem?
Keith
Convert to disc brakes.
Old 02-10-2011, 02:12 AM   #3
62 Bowtie
62 Bowtie's Avatar
Re: lower a-arms
yes at the shaft with the bushings is tight i loosened the nuts and it got a little better but still no go and they are old i tried to have the bushings replaced at a shop and the guy said the arms were flexing and he didnt want to bend them, the upper bushings are new and operate smoothly.Now as far as the wiring i'm not sure whats going on. its pretty straight forward color coded but when i accuate a switch say #1 the right rear moves and its supposed to be the left front one more thing when I use a schrader with a tee in front it does raise and lower
Old 02-10-2011, 11:08 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: lower a-arms
Sounds like your supply lines are routed to the wrong valves.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-10-2011, 09:52 PM   #5
62 Bowtie
62 Bowtie's Avatar
Re: lower a-arms
thought that too so i moved the lines to a known good line and nothin in other words the lines work for the rear but when i remove the lines from the rear ports of the manifold and plug in the front lines to the same ports i get nothing heres a pic
