Enjoying left field
52" leaf springs on a 70 K10
I'm building a 70 K10, and I'm putting 52" springs on the front. I would love to buy the Diy kit, but I can fab my own stuff alot cheaper. Does anybody have any pictures of their install? I would just like some side shots for reference. Has anybody used 56" springs for the rear? I'm converting a coilspring rear 2wd frame, so i'm building new mounts anyway.
![]() Join Date: May 2007
Re: 52" leaf springs on a 70 K10
If you are doing 52 in the front step up to 63 for the rear. Just do a search for pics of a install.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
Enjoying left field
I've been searching for 4 days on here, pirate, and coloradok5. I've been having ahard time finding good pictures. I think there is a good build on coloradok5, but you've got to pay to see the pictures. What did the 63" springs come on?
![]() Join Date: Feb 2007
63" springs came on the rears of '88-'98 1/2 tons. What are your plans for your truck? Are you looking for flex or ride?
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
Enjoying left field
With the 52's in the front, i'm looking for a cheap 5" lift, and a better ride. I plan on running a sway bar. And Duallyjams just recommended 63's in the rear. I probly won't wheel much.
Keep me posted if you do this, I'd like pics. I have considered 52's in the front and planned on 56's in back. This is for my daily driver and I too would be looking for ride quality.
I'm interested in this as well. I've been doing a bunch of work on my '71 lately and the ride quality is terrible. It has factory springs with 32's and could use about 2 more inches of lift. Are the 52" from the 73 and later trucks I'm assuming? And which mounting points need to be changed? Front or rear?
1964 C10 Shortened Shortbed Cammed LQ9 P&P 1967 C10 Trophy Truck BB 438 (soon to be worked on again) |
![]() Join Date: Apr 2008
I was just on their site looking at that kit. It's pretty nice, but for the money I would rather build the bracketry and spend the dough on the springs. I just went outside and measured my stock, dearched, 2 thick springs at 44"
Enjoying left field
The 52" springs are what's on the rear of our 1/2 trucks, up til 87 I think. The ones I'm useing came off a late 70s suburban. I read somewhere that you should look for springs from a 2wd since they probably weren't abused as bad. You have to move both spring mounts a few inches. I just started a new build thread. One of the first things I'm doing is the front springs.
http://67-72chevytrucks.com/vboard/s...d.php?t=446024 Posted via Mobile Device |
I did the swap to 52's, but I used a slider for the rear mount so that I had less lift. Ended up with about 3".
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
What's a slider? Have a pic?
Yes lets see a pic. That's all the height that I'd need.
