Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
1966 LWB Truck 1
I should have taken more pictures with this but...my bad....So I started out by purchasing this at the portland swap meet all most 2 years ago now....I drove it around just the way it was then decided that I wanted to up grade...So I ripped all the old rotten oak out and replaced all of that by making my own kit....It had been lowered with a torch and really needed the works and a disc brake kit...
Re: 1966 LWB Truck 1
So off i went...new 2.5" drop spindles with upper and lowers..3" drop coils in the front and 4 "drop coils in the back...new brakes all the way around.Converted it all over to 5 bolt and added a new master cylinder and booster...Tried my hand at a new seat skin and wrapped the old seat and found some wheels i liked.....and here is the result so far.
I have less then 250 miles on it with all the new gear and it drives awsome. It's like a brand new truck......So.....what the heck off to the body shopfor my buddy to help me out ( again )
The last set was done on friday....and there it sits on the hoist
![]() Join Date: Mar 2005
I love the way it sits. So to get it there took 2.5" spindles, 3" dropped coils in the front, and a 4" dropped coil in the rear?
I know you said it rode awesome, but how does it handle the bumps? Does it bottom out anywhere? I'm seriously considering copying your set-up for mine.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
My bad...I just looked...I used 2.5" drop spindles and 3" drop coils up front.....and then i went with 5" drop coils in the back....It was mostly a CPP thing but I went with McGaughys drop spindles. I wouldn't go any lower with out taking out the front cross member. Granted I am running 15" wheels with low rubber but it rides awsome I really like it. But the cross member is low upfront.
NIce Truck man....I like it.
That Portland swap meet is in April. I'll be there this year
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
Hey don't buy the doors and hood i need.....for my pro street truck. I bet there will be a bunch of us down for that, might be a great place to meet some of you truck guy's before we try to buy each others parts....thanks
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Checkin in on this build also..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
I hope the pull the engine out of this maybe this weekend.....turns out i have more projects then I do hands...lol
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
Okay so this project is really far behind but it is starting to move again....it took a while to pick out the color but so far i think it's going to look wicked in these colors...
It was a bit of a tough choice but i decided to do the entire inside in the same blue....I think i will put a bit of white on the wheel to just to break it up....But am really having a tought time trying to decide if i want to baseball cap it on white.....or do the entire outside of the cab in blue....just can't decide and am headed to look at pictures to decide....
Now thats some blue going on in there isn't it ....
PROJECT 7DEUCE
Sucker looks great..
#15 |
thats a cool shade of blue!
Cam 1972 Chevy C/10 "Custom Cruiser Project" Build Thread 1961 Olds Super 88 (Daily) 1966 Chevy Corvair 500, "Marigold" SOLD 2005 Subaru Outback Wagon DEAD 2008 Pontiac G8, New Winter/Daily |
#16 |
I would like to find a picture of a long box small winow in a close color to see if i want the top of the cab white or the same blue.....almost all of the white cabs i can find are a really light base color....not sure how it will look with a white cap on that....It does have the white stripe and all of the trim on the side of it...but i just don't know
#17 |
I'd get the bed installed, color sand and buff everthing from the window openings down, put the tires and wheels back on it, and then stand back and look at it from every angle for a day or two.
A white top will definately give it a more stock-looking appearance, while the blue top will give it more of a hot rod flavor. You'll just have to stand back and look at it for awhile. To me, being as the interior is now blue, I'd leave the top blue as well. That truck is going to look nice regardless of what color you choose.
#18 |
Thanks Resto..
I appreciate the feedback... I redid the boards....they are ready to go .... I think i am leaning to go with the blue.....should be okay with the custom trim pieces.. -------------------------------------------------------------------------------------------- chevyrestoguy Re: 1966 LWB Truck 1 -------------------------------------------------------------------------------- I'd get the bed installed, color sand and buff everthing from the window openings down, put the tires and wheels back on it, and then stand back and look at it from every angle for a day or two. A white top will definately give it a more stock-looking appearance, while the blue top will give it more of a hot rod flavor. You'll just have to stand back and look at it for awhile. To me, being as the interior is now blue, I'd leave the top blue as well. That truck is going to look nice regardless of what color you choose.
#19 |
I didn't realize I wasn't subscribed to all your threads...so um...now I am
![]() 1966 C10 LWB, 283, 3 on the tree (lots of work to do!) http://67-72chevytrucks.com/vboard/s...d.php?t=471348 2001 Suburban daily driver 2008 HHR (wife's ride) |
#20 |
Ya know i feel bad for this build......I built this thing in a couple of weeks...I put new rear axles....rear brakes...5 "drop coils ..new drums in rear.....Then in the front new upper and lowers...2.5 inch drop spindles....3" drop coils....new master cylinder...new booster...dropped in a HEI....New 2.5" dual exhaust...re did the seat....and then it sat in body shop jail for months waiting and waiting.....but it should be on the road tomorrow...crosses my fingers.
#21 |
But it's getting warmer......not sure what too think of the cap white yet it's going to take some time....
#22 |
Can it really be this close ?.......but it is ......but it is ....lol
#23 |
this truck is just as nice as the rest of your trucks!! i like the white cap it breaks it up a bit! and the blue makes it pop!!
#24 |
Thanks....
I am not to sure about the white cap on it just yet.....but i thought i would give it a try and see how it looked....it's a differnt look ....maybe it will grow on me
#25 |
Redneck Hillbilly
I like it, the white cap helps keep it kind of classic looking, especially since you put the white in between the trim pices. Cool pickup.
