Old 02-27-2011, 08:57 PM   #1
hotrod_991
hotrod_991's Avatar
Exclamation Ignition help!!!
I just go0t my engine back from the builder and im haveing issues getting it to fire. I installed a new electric fuel pump and am getting right at 7psi at the carb so no fueling issue, and i layed a plug on the frame and it sparked so im getting spark but it still will not fire at all just cranks till its flooded. I checked then double checked the wire and they are all in the right spots. Im at the end of ideas with it. I have an MSD ignition with the 6A box and when the key is turned on i hear an audable cherp like sound conming from it. Anyone ever had this issue? I have to have it running by tomarrow night as I have to use it for work Tuesday morning so i need some help fast. Thanks everyone.
"Buckle up I wanna try somethin!!"
"of course it will hold!, I welded it!"
1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint
hotrod_991 is offline   Reply With Quote
