Old 02-28-2011, 04:27 AM   #1
junkyardjohn
junkyardjohn's Avatar
Door sill idea
I'VE FOUND THAT YOU CAN USE 67-72 DOOR SILLS ON A 73-91 BLAZER, IT JUST TAKE A LITTLE MASAGING WITH A RUBBER DEAD BLOW MALLET. FIRST YOU PUT IN THE CENTER SCREWS (YOU MAY HAVE TO DRILL NEW HOLES & THE OLD ONES WELD UP EASILY) & BEND THE ENDS IN THE RIGHT POSITION, & BEAT IN PLACE WITH A RUBBER MALLET. (I PAINTED MINE BLACK CAUSE IT'S A MILTARY CUCV BLAZER... NO SHINY STUFF) THEY LOOK 100 TIMES BETTER & ARE A VAST IPROVEMENT OVER THE FACTORY CHEASY ALUMINUM ONES. HERES A COUPLE OF PICS. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 03-04-2011, 10:38 PM   #2
4pilgrim4
Re: Door sill idea
Looks better than the stock aluminum sills, in my estimation.
Where did you get your 67 to 72 sills?
4pilgrim4 is offline   Reply With Quote
Old 03-05-2011, 03:10 PM   #3
junkyardjohn
Re: Door sill idea
I'VE BEEN DOING 67-72 TRUCKS FOR A LONG LONG TIME & HAD EM IN THE SHOP, BUT NEW REPOP ONES ARE ONLY ABOUT $22 A PAIR, OR LOOK ON THE 67-72 PARTS SECTION OF THIS BOARD & I'LL BET YOU CAN FIND A GOOD USED SET. THEY'RE CHROME, BUT I PAINTED MINE FLAT BLACK BECAUSE THIS IS ON MY OLD CUCV MILITARY BLAZER... NO SHINY STUFF ON THAT. JOHN
junkyardjohn
DON'T RENT U-HAUL
