Old 03-10-2004, 11:54 PM   #1
iufan71
Question Dome Light Problem?
I'm trying to figure out why the dome light in my 78 GMC isnt working. I seem to be getting voltage at the light it self,but exaclty how many volts should I be getting at the light?The entire 12 volts,or less than that?
iufan71 is offline   Reply With Quote
Old 03-11-2004, 12:17 AM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
the lamp has a constant 12V all the time. It is turned on by the door switches or light switch. These ground the circuit causing the lamp to light.
NeCrOmAnCeR is offline   Reply With Quote
Old 03-07-2011, 05:03 PM   #3
BuckB78GMC
BuckB78GMC's Avatar
Re: Dome Light Problem?
uifan71, thanks for asking the question. I am having the same issue with my 78 GMC.
BuckB78GMC is offline   Reply With Quote
Old 03-07-2011, 05:06 PM   #4
BuckB78GMC
BuckB78GMC's Avatar
NeCrOmAnCeR, thanks to you also for the heads-up on how this thing works. I had been looking around the net for a wiring schematic of the system but this makes it really easy to figure out.
Old 03-07-2011, 11:31 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
the switch might be dirty in the jam
the ground goes threw a white wire
comes into the cab with a black rubber grommet just under the dash lip at each side
some people cut the wire @ the switch or fuse panel to make the dimmer switch the only way on
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
