Old 02-20-2017, 02:47 PM   #1
HunterRotten
HunterRotten's Avatar
Leaky diff and how to remove undercoat efficiently?
My dad and I took the bed off yesterday and noticed the rear diff was leaking from just about every place it could.. how should we go about that?
Also, we are going to either POR 15 the underside of the bed or new undercoat. What's the best way to remove what's there already? I am going at it with a scraper and it is very tiring and time consuming but the fastest and cleanest way I've found.
Thanks!
HunterRotten is offline   Reply With Quote
Old 02-20-2017, 06:37 PM   #2
Gmc.guy
Gmc.guy's Avatar
Re: Leaky diff and how to remove undercoat efficiently?
If you have one of those little torches that go on a little propane tank it helps to warm the stuff up just ahead of the scraper as you go. Depends on what the stuff is. Might help you out
-Cody
Gmc.guy is offline   Reply With Quote
Old 02-21-2017, 07:48 AM   #3
ACS
If you have access to a decent compressor, I'd try a needle scaler to peel the undercoating off.
ACS is offline   Reply With Quote
