What options for steering coluum?
I was wondering what my options would be on a coluum? I see the new ones are $500 and up and was hopeing that there was a scrap yard solution. Truck has a 77 camaro front clip in it with powersteering... But a terrible looking coluum...
Would liek to get one from a car to put in it but do not have a clue what to look for... A 500 dollar coluum is not in the budget right now.. You can see somewhat of what it is in the truck now below... The ad on turn signal box does nothing for me... Truck is an suto... ![]()
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon. |
Re: What options for steering coluum?
late 60's early 70's chevy van tilt is one of the best choices. What ever you use don't get one with a key in it.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
![]() Join Date: Nov 2008
Here mine 85 Chevy van, you get ign switch and tranny gear selector, cruise and intermitent wipers. The steering wheel is early 90 Blazer.
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
I used an 82 Eldorado because it is tilt telescope, has the dimmer, locking ignition and cruise (future possibility) and is only 30" which reduces conflict with exhaust maniford. I also wanted the shift on the column to keep the floor and third seat position clear. Heres a photo, I will eventually change the wheel.
I never did like the dimmer on the column because I always got my foot hung in the steering when i met a car... Very dangerous!
Actually, i like to drive old vehicles because they look old. The dimmer in the floor is much easier for me because i either have one arm out the window, or the other arm around a girl (not at the same time, lol) and the key in the dash is just where it should be. Looks much better where it belongs ![]() In my opinion, of course
![]() Join Date: Jul 2007
Actually a 71/71 Pickup column should fit in there and look pretty clean. If you are running a floor shift the columns out of the 4 speed trucks are really clean.
Turn signal switches are still inexpensive and easy to get and wheel adapters will allow you to put most any custom wheel on one. The Chevrolet van tilt columns w/o the ign switch are real popular and also pretty clean for a tilt. |
i am using a 68 c10 steering column and it fits the stock clamp/bracket under the dash and looks great. i picked mine up for $20.00 and needed to clean and paint it.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
polishing a turd
i am using the tilt column from the 77 nova that i took the clip and rear axle from
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
Well, I just built one for this same reason. I didn't want the key on the column and the 67-72 column I had was way to long and reached in behind the frame. (might be ok if your using a rack & pinion. But, doing the Power Steering swap on my dads 55 I needed a column that would stop close the F/W this way the auto shifter woudn't contact the exhaust manifold or valve covers. So because the steering box is outside the frame a rag joint cant be used (as a u-joint) And the ford column has a rag joint right at the end. I removed the shaft from the column from both of the column I had laying around and welded a piece of the chevy shaft on the end of the now cut off ford shaft. It's clean its exactly what we wanted and for me it was free.
So, if your looking for the same thing I was as a finished product, you can use one out of an late 60's early 70's ford. You just have to modify the shaft. The column Lenth is 32" instead of 35
There are two kinds of people, those who finish what they start and so on. 70 GMC Longhorn (A.K.A Money Bucket) 57 Chev 3100 05 Chevy LLY Dmax. 67 Chevy Camaro Dad's Budget Build 55 My Longhorn Build |
Commander Taco Bello
seems to me that then 67-72 column would be to long on the inside of the cab. However, i think it would look great since it has no shifter or ignition.
i think i'm going to have to go junk yardin' to find something i like. anyone else have some suggestions? In my case i'm running a rack and plan to have 2 u-joints in the shaft to make it work.
I just cut 5" out, and shaved the shifter off of a late 60's car column to put in my old couple. If you like the column don't worry about how long it is. Now, one of the newer ones would be a different story, but I like the no key look.
A320 Pilot/USAF Retired
I liked a shortened van column myslef. Have a look at the pics I put up today in my build thread.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
Just a few shots of a SO FAR project! Relocated Tank / Installed Disc Brakes / Big Surprise to many ? Original GMC Power Steering, with stock 2 piece column
If you are looking for a
tilt steel column we sell Ididit and have them in stock Starting price is $300.00 plus ups and come with a lifetime gaurantee call us up \(805)485-0382 www.scottshotrods.com Thankyou, Justin |
#15 | |
#16 | |
ups. Justin www.scottshotrods.com |
#17 |
It's off topic from this thread, but what gas tank is that that you have there?
#18 |
#19 |
![]() Join Date: Mar 2008
There's another topic on tank and he said it's a '70 mustang.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
#20 | |
Autronic Eye... Automatically dimms high beams when the sensor sees oncoming headlights
1955 2nd Series 3100 - 400 Pontiac / BW Super T-10 4-Speed 1972 K5 Blazer 350 Auto 4x4 1928 Ford Model A Tudor Last edited by Maximus; 03-15-2011 at 02:27 PM. |
