Old 04-19-2011, 01:59 AM   #1
Beat68CST
Beat68CST's Avatar
Rear sway bar
Do coil spring rear trucks have sway bars at all? I know they have the centering link that goes side to side.
Beat68CST is offline   Reply With Quote
Old 04-19-2011, 08:51 AM   #2
cdowns
cdowns's Avatar
Re: Rear sway bar
did not come from factory with swaybar option
aftermarket (helwig) units are available and effective a lot of guys also use some imagination and convert factory type swaybars to work well
Old 04-19-2011, 11:48 AM   #3
profe56
Re: Rear sway bar
can we seePictures?
profe56 is offline   Reply With Quote
Old 04-19-2011, 11:52 AM   #4
Beat68CST
Beat68CST's Avatar
Re: Rear sway bar
Originally Posted by profe56 View Post
can we see pictures?
x2
Once I put bags (for heavy loads) on the rear of my truck I'd love to put the sway bar in at the same time.
Old 04-19-2011, 12:58 PM   #5
Classic69
Love That '69
Classic69's Avatar
Re: Rear sway bar
Originally Posted by cdowns View Post
...a lot of guys also use some imagination and convert factory type sway bars to work well...
Factory ones work great at a fraction of the cost & with very little modification. I installed a front sway bar from a late '70s chevy pickup and a rear sway bar from an early '90s camaro Z28, just had to mount some 1" spacer blocks in the rear to mount to the frame & I replaced the worn out rubber bushings with new polyurethane ones from NAPA.
The front/rear sway bars made a world of difference in handling!!
I AM CANADIAN!!!!!
1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights
2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates
Classic69 is offline   Reply With Quote
Old 04-19-2011, 01:03 PM   #6
Beat68CST
Beat68CST's Avatar
Re: Rear sway bar
Could you set us up with some pics and measurement of the rear one?!
Old 04-19-2011, 01:12 PM   #7
Classic69
Love That '69
Classic69's Avatar
Re: Rear sway bar
I used this link to install my rear sway bar on my '69
http://www.low69cst.freeservers.com/CamaroBar.htm
Includes some pics and a detailed "how to" install for it...
I AM CANADIAN!!!!!
Old 04-19-2011, 05:09 PM   #8
profe56
Re: Rear sway bar
Thanks!!! I knew someone did it before, because I'm swaping a 94 rearend and has brakets that hold the sway bar and I'll see more slow your article to understand it.
Old 04-19-2011, 09:03 PM   #9
treveiger
treveiger's Avatar
Re: Rear sway bar
Saving this one
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 04-20-2011, 02:24 PM   #10
s_nova69
Re: Rear sway bar
Here is mine. It is a camaro rear 7/8" adco sway bar. I have not driven with it but found the method here on this site.
Phil
'70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver
'72 short super build
4wd '72 Suburban LT4 coming soon!!
s_nova69 is offline   Reply With Quote
