meowMEOWmeowMEOW
Driveshaft time
So I have NEVER done anything with a driveshaft in my automotive life. I can replace a u-joint fine, but have never measured for or really worked with a drive shaft.
The truck is my 66 short bed step side. Old setup WAS 355 w/700r4 to 12 bolt NEW setup IS lq4 w/4l80e to 12 bolt. I thought I might be able to have the existing shaft modified to fit, but its actually too short, not too long. How do I know what ends I need, and how to measure for the shaft? I have read a few different instructions but it seems like the measurements I get, don't really make sense against what I'm reading. Any help? Pics would be great. Also, do I need to buy a seperate yoke for the trans? or does it come on the new shaft?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
![]() Join Date: Aug 2004
Re: Driveshaft time
If you have a reputable driveline shop in your area, you can call them and tell them what trans you have, and measure from center of rear u-joint to the end of the tranny tailshaft, they will make you one and balance it
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Has more rust than truck...
Re: Driveshaft time
I bookmarked this back in 07 when I started researching a LS swap.
http://www.automedia.com/Building_a_...es20040301ds/1 |
meowMEOWmeowMEOW
Re: Driveshaft time
good info, strangely, the man measuring the shaft looking Amish.
![]() Join Date: Nov 2007
Re: Driveshaft time
This is the Dana-Spicer u-joint catalog. Look under conversion u-joint kits if you want to adapt a particular drive shaft to another transmission or differential.
http://www2.dana.com/pdf/K350-1-DSSP.pdf It takes a little head scratchin but it is all in there. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
Addicted to Rust
![]() Join Date: Dec 2009
Re: Driveshaft time
http://www.dynotechengineering.com/
They have made a couple of shafts for me. Fast service and the will help you decide what you need for your application. Jay
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
![]() Join Date: Aug 2010
Re: Driveshaft time
This is where I got mine done. I think it was around $250 for them to shorten it, install a new 27 spline slip shaft, and all new U-joints.http://www.iedls.com/Driveshafts/Mea...riveshafts.asp
67 5.3L Build |
