Old 04-29-2011, 07:39 PM   #1
csa daddy
csa daddy's Avatar
swaybar to replace track bar
can i use a sway bar to replace the track bar on the rear of my 64 chevy with trailing arms. im planning to bag this truck just trying to figure a way to keep axle centered with factory arms
csa daddy is offline   Reply With Quote
Old 04-30-2011, 12:08 AM   #2
SCOTI
SCOTI's Avatar
Re: swaybar to replace track bar
The sway bar helps prevent 'leaning' (for lack of a better description).
The Panhard bar (track bar) used in conjunction w/the truck arms keeps the axle centered relative to the frame but is limited in it's range vs. amount of side shift allowed. The longer the bar, the less side shift so using one as long as possible within your available space is the way to go. Another option is the Watt's link. It helps keep the axle centered exactly throughout travel but is definitely more complicated to set up.
The sway bar in it's basic design won't do the job of the Panhard bar.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-30-2011, 12:58 AM   #3
67c10rustbuket
67c10rustbuket's Avatar
Exactly, what SCOTI said, if your going to bag it get a watts link . It will keep your axle centered all the way up and down, the rear sway bar is only designed to reduce sway at one height. you will create some akward angles and side shift with only a sway bar, that the sway bar cannot correct with a bagged suspension.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 04-30-2011, 01:14 AM   #4
VA72C10
VA72C10
VA72C10's Avatar
sway bar would be a nice addition but you will still need a watts link or another option is an adjustable panhard bar if you're going to keep the driving height at a pretty standard preset. Can get it adjusted at ride height to center the axle. And those adjustable bars can be had CHEAP on ebay....
Old 04-30-2011, 08:10 AM   #5
csa daddy
csa daddy's Avatar
thanks everyone i looked at the watts link but they are rediculous in price. i mean they sd wants almost 500 for their watts link. plus i dont really have the room to do a watts behind axle cause i want to run a blazer tank in the back
Old 04-30-2011, 09:51 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
You don't "need" a Watts link. Buy an adjustable track bar, center your axle at ride height, and call it done
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-30-2011, 12:40 PM   #7
csa daddy
csa daddy's Avatar
but i want the axle to stay straight all the way up an down an the track bar wont let me do it
Old 04-30-2011, 12:47 PM   #8
mbgmike
We can build you one
mbgmike is offline   Reply With Quote
Old 04-30-2011, 01:10 PM   #9
62 Bowtie
62 Bowtie's Avatar
Me too!
62 Bowtie is offline   Reply With Quote
Old 04-30-2011, 01:11 PM   #10
62 Bowtie
62 Bowtie's Avatar
Build one what? Sorry csa don't mean to jack your thread
Old 04-30-2011, 01:40 PM   #11
csa daddy
csa daddy's Avatar
no prob. he is probbly talking a watts link. an how much would said watts link cast an how far behind the axle cover will it be at its furthest point
Old 04-30-2011, 02:22 PM   #12
mbgmike
yes the watts link. Don't know on cost but should not be anywhere near $500.00 I will have to talk to Ronnie and see what he thinks. He can fab anything. Even Top fuel chassis's and rear ends. He is a CrewChief on a top fuel dragster, give us a dimension you have to live with
Old 04-30-2011, 03:50 PM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
So convert it to leaf springs, or a 3 link.
Articles-
"Refining Sierra"
Old 04-30-2011, 05:56 PM   #14
csa daddy
csa daddy's Avatar
was wondering it i put in a triangulated top bar on the rear with factory arms if that would take care of it
Old 05-01-2011, 06:29 AM   #15
andrewmp6
You know a bolt in watts link is 369 bucks http://www.kplinks.com/product.php?p...&cat=98&page=1 if you want cheaper talk to a local chassis shop they can build one that will fit even with the blazer tank in there.
Old 05-01-2011, 10:59 AM   #16
csa daddy
csa daddy's Avatar
on average how far behind the dif cover does the watts sit.
