Gas gauge problems
Gas gauge was on empty for some time now, just moving the truck in and out of the shop, around the yard etc. so it wasnt a big deal, I just figured it was empty. Well yesterday I figured I better dump some fuel in it. i put 5 gallons in and it gave me 1/8th of a tank. I disconnected the sending unit wire and the gauge seems to work fine. Ideas?
Active Member
![]() Join Date: Jul 2007
Re: Gas gauge problems
Could be that it may need more gas. If it was completely empty, it takes a few gals to move the float from the bottom.
The float does not rest on the very bottom and by the time the fluid reaches it you'll have a few gallons on the bottom and your gas gauge won't show the whole amount. As you know, on most cars and trucks when the gauge reaches empty you still have some fuel to go farther. |
#3 | |
Active Member
I've had mine down to empty in the past and never been able to put 20 gallons in it. The gauge is just a "ballpark" type of gauge. They're not super accurate and 1/2 tank may not mean you have exactly 10 gallons in it. You could have 11 to 12 left in there.
The best way to tell if the sending unit/gauge are working fairly close as a unit is to fill the tank up and see if the gauge goes all the way to full when the pump clicks off. Don't overfill it and make sure you don't park at a slant with the drivers side lower than the passenger side otherwise it may seep out of the fill tube. |
According to my owner's manual, the stock in-cab tank holds 18.5 gallons. My truck usually takes 15-16 gallons when the gauge is on 1/8 of a tank.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS ![]() -1983 Chevy Silverado C1500- 383 stroker, TH400 -1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears -And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket "The only thing we have to fear is fear itself." -FDR (and maybe rust too) ![]() You've gotta be able to stop and steer before you can go fast! |
sharp as a marble
![]() Join Date: Jan 2007
disconnect the sending unit wire, connect a test light to it, and look carefully. You should see a pulsing dim light. If you do the wiring and gauge should be good. The float could be full of gas, and reading empty all of the time. The brass floats had ends soldered on them, and will leak fuel into them. If the tank is really empty, remove the sender and then remove the float from the hanger and shake it. If you feel something in it, there is your problem.
Chip |
![]() Join Date: Jun 2005
I have the opposite problem, sort of. My gauge always worked correctly until recently, I noticed when i fill it up the gauge goes WAY past full. What would cause this?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#8 | |
Mine was the same issue. Sending unit was bad. And by bad, I don't just mean it wasn't working - the PO had cobbled together a "universal" one with a bunch of hose clamps, a coat hanger, and rubber line. Cheapest replacement I found was Classic Chevy - $30, where LMC was 50.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
#9 | |
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
Today, the fuel gauge on my 68 seemed to quit working. when I parked it yesterday, it was at 1/2 tank. Got in it today and it was reading 1/8 tank. Went and put gas in it, cause I figured someone siphoned my tank (also bought a locking cap), but now its reading dead empty.
Make sure the wire is good from the sending unit to the fuse block, and that it is connected. Tank ground should be good too.
Sender should read between 0 and 90 ohms if good.
I personally don't like the locking caps. If someone wants the gas, they're alreading prowling around with tools to rip or pry open hatches, caps or what ever. This tells me if they do that to a Chevy gas cap that locks....the tank neck could get buggered up also.
