Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-04-2010, 11:25 PM   #1
midevil1
ShortBus KingPin
midevil1's Avatar
Homebuilt headers
I just wanted to show you guys my headers that I am building for my 67. You all know we dont have any good choices in headers without paying a fortune.
These were built from 2.25 316SS tubing. custom 316SS 3/8 flanges, cone engineering 316SS collectors with turbo stars. I used SS v-band flanges for a leak free seal to the exhaust pipes. I still have to grind down the welds and send them to Poly-Dyne down the street for Ceramic Coating. I have about 350.00 in materials. Took me about 10 hours to mock up and weld. Tell me what ya think.....
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE)
2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE)
2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE)
midevil1 is offline   Reply With Quote
Old 04-04-2010, 11:34 PM   #2
midevil1
ShortBus KingPin
midevil1's Avatar
Re: Homebuilt headers
couple more pics
Old 04-05-2010, 08:37 AM   #3
djracer
djracer's Avatar
looks pretty good I may have to do something similiar.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-05-2010, 09:11 AM   #4
Alex1
Alex1's Avatar
Excellent! I like the design.
Looks like these:
http://www.fabshopheaders.com/catego...downswept.html
I spoke to them and people do buy them for their 2wd Chev trucks ut you need to trim the control arm.
Alex1 is offline   Reply With Quote
Old 04-05-2010, 09:55 AM   #5
midevil1
ShortBus KingPin
midevil1's Avatar
I built my own because not one header company was willing to make the "correct" flanges for the PRO1 style square exhaust port. I had my buddy waterjet me a set of perfect flanges and the matching copper gaskets for them.
I went with fenderwell type headers for the sake of the starter and I have a GEN V block with the built in driverside oil cooling that I am utilizing.
Old 04-05-2010, 02:44 PM   #6
Marv D
Registered Truck Offender
Marv D's Avatar
You have WAY more time, patients (and skill) than I do. I tried to make my headers (inside the frame) and promptly decided it was just more than I was willing to deal with. Took me a week to build 2 tubes!! (and I have a pile of scrap pieces to prove it!!!!). I was targeting 42" to 46" lengths, and staying inside the frame, not dissecting my aluminum inner fender panels, and have the slip collector supported at the trans cross member. (I AM my own worst enemy for SURE).
You have my sincerest appreciation for your work there,, KUDOS to you!!!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 04-05-2010, 07:22 PM   #7
midevil1
ShortBus KingPin
midevil1's Avatar
I appreciate your comments MARV. I do understand why these headers are so expensive. Alot of time and skill go into making them. It can get REAL expensive if you rush and screw up on cuts over and over again.
Old 04-06-2010, 02:53 AM   #8
team39763
Nice work man.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 05-25-2010, 11:50 PM   #9
midevil1
ShortBus KingPin
midevil1's Avatar
headers and exhaust finished and installed. Wondering what these race bullets are gonna sound like....
Old 05-26-2010, 12:31 AM   #10
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
the bullets will be pretty quiet
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 05-26-2010, 12:51 AM   #11
noonzor
very nice man!! i hope to do my own headers too.
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 05-28-2010, 10:24 AM   #12
shortbed70
shortbed70's Avatar
Those are bad man I have tossed around the idea of doing that with my 65 sbc but I dont have patients to build them. Cant wait for sound clip.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-29-2010, 08:56 AM   #13
Wild83C10
Wild83C10's Avatar
Now you need to send those to a tubing bender and then you can start selling a few.
Nice work. I was thinking of making my own headers for my turbo setup, but don't really have the patients I would have been in the same boat as Marv. I did build my hot side and that was a bit more then I wanted to do.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 05-29-2010, 05:38 PM   #14
AKoldstyle
AKoldstyle's Avatar
Thumbs up Re: Homebuilt headers
I like the fit from what i can see. I was able to get my 2" hooker super comps to fit quite well. I did however lower and set my engine back aways,which now makes the drivers side closer to the frame underneath at the back,I also plassed my rails alittle for clearance. I keep hearing that i should have bigger pipes on this. I noticed you where not able to make equal length tubes ? look like you made a nice exhaust good fabing.
AKoldstyle is offline   Reply With Quote
Old 05-29-2010, 06:59 PM   #15
Alex1
Alex1's Avatar
Love the V band connection -aren't they awesome!
Old 05-31-2010, 03:52 AM   #16
midevil1
ShortBus KingPin
midevil1's Avatar
Thanks Everybody. The headers really weren't that bad to make. I really liked them tonight. since my NEW Protorque CVR starter already took a CRAP. Didn't have to worry about them being in the way. The Bullets sound NASTY BTW, What I heard of them before the starter crapped the bed.
Old 06-03-2010, 09:48 PM   #17
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Sorry to hear that. Wicked looking headers, though. I bet they DO sound good.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 06-03-2010, 10:37 PM   #18
midevil1
ShortBus KingPin
midevil1's Avatar
Hope to have some sound slips and video's of the exhaust this weekend. When I get back home from work. My rebuilt starter will be waiting for me.
Old 06-03-2010, 11:03 PM   #19
PhilaTruck
PhilaTruck's Avatar
Very cool, thanks-
Subscribe here!
Old 06-05-2010, 01:25 AM   #20
454HO
Nice work. I see you used Dynomax bends. I am building an exhaust system for one of my project cars with Dynomax mild steel bends and am having a slight issue with inconsistent pipe size. It seems when I cut a bend somewhere in the middle and then join it to a straight piece of pipe cut from the same bend, the diameter of the pipe doesn't line up just right. The bend is always smaller diameter than the straight piece. And here I though a mandrel bent pipe kept the same diameter throughout... but apparantly it does not. Makes it a pain to weld the pieces together without a step on the inside. Did you see the same thing on yours?
Also I noticed you are in Houston (me too) and were going to have your headers coated at Poly-Dyne. But in your post of the finished headers they are wrapped with tape. Did you do both, or just decided to wrap instead of coat? I have used Poly-Dyne to coat exhaust parts in the past and they did an excellent job, but they would not use the shiney ceramic coating. I ended up using what they called Titanium color.
- Greg
454HO is offline   Reply With Quote
Old 06-05-2010, 01:58 AM   #21
midevil1
ShortBus KingPin
midevil1's Avatar
I didnt have any problems with the 2.25 ss bends. I had them coated in black and then wrapped them. I dont want to burn myself and I am a FIRM believer in low underhood temps. Especially here in HOUSTON. I am all about gettin together with other members here in Houston. Usually at the Spring-Cypress car show on sat. nights.
BTW, Got her running tonight. Video tommorrow or today. Bullets are NOT quiet and she hits HARD!!!!!
Old 06-05-2010, 06:15 AM   #22
darthwall
can't wait to hear the the sound of this
darthwall is offline   Reply With Quote
Old 06-05-2010, 05:40 PM   #23
noonzor
need soouuunndd!!!
Old 06-05-2010, 05:54 PM   #24
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
I agree you could sell a pile of them to us guys who can't get the exhaust out because were to low...we could easily exit in front of the rear wheel instead of dumping them infront of the axle......an I AGREE on the wrap I'm going to do mine when I have the exhaust built for the caddy
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 06-06-2010, 12:38 AM   #25
midevil1
ShortBus KingPin
midevil1's Avatar
1 quick video. more tommorrow. kinda echoing in garage.
