Old 04-30-2011, 10:52 PM   #1
AusTx68
AusTx68's Avatar
Installed AVS Shaved Door Kit
After looking at shaved door kits I went with a 4 channel kit from AVS. I picked it up from ridinglowcustoms.com for $150. Came with dual actuators, wiring harness and key fobs. The photo is of the 8 channel kit but it looks the same. I searched this forum for actuator install photos but didn't see any so I thought to share how I mounted mine.
AVS makes a 4, 8, and 12 channel kit. I only needed it for my doors so 4 channels was 2 too many. Leaves me room for creativity later The install was pretty straight forward. I started on the drivers door which took twice as long to install because I had to determine actuator location and figure out how to run the cables. Speaking of cables, this kit replaces the stock door rods with a cable to the latch and inside door handle. You still use the inside door handle to get out. As you can see in the photo I mounted the actuator across the inner hole of the door using brackets that came with the kit. This location leaves plenty of room for window operation. There's an optional cable guide to keep the wire from laying on the actuator (shown). Once I got the actuators in place the rest was easy thanks to the wiring harness. Just plug it all up and run the power. It opened the door on the first try but wouldn't fully close. I loosen the cable in the actuator and it fixed the problem. During testing the doors opened nicely. I have new door rubber so there is plenty pressure to push open the door without the need for pushers.
Overall the install was quick and simple. I'm definitely happy with it. If you are looking to do the same I hope this posting helps.
The bracket on the right is only mounted on the bottom which is why I put two screws.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 05-02-2011, 11:41 AM   #2
colin_havens
colin_havens's Avatar
Re: Installed AVS Shaved Door Kit
Nice job! Did you switch to bearclaw latches as well, or use the origional ones? i have heard you had to switch, so I havent even looked into doing this when I repaint due to the additional cost.
colin_havens is offline   Reply With Quote
Old 05-02-2011, 11:59 AM   #3
Tim R
I Agree nice joband thanks for the information . I am ordering the same kit this week . Glad to know it works well . I have really been worrying about which kit to buy. I was leaning towards this one because of the dual motors.
Thanks Tim
Tim R is offline   Reply With Quote
Old 05-02-2011, 01:10 PM   #4
Gobbles
Gobbles's Avatar
You have a gorgeous truck, also interested if you used bear claws!
Trevor
"You already said spite"
Gobbles is offline   Reply With Quote
Old 05-02-2011, 05:25 PM   #5
AusTx68
AusTx68's Avatar
Nope, didn't use bear claws. The stock latch worked fine. I simply connected the cable where the rod used to be and it opens with no issues.
Old 05-02-2011, 05:33 PM   #6
West Texas Z
El Mero Mero Frijolero!!
West Texas Z's Avatar
impressive. Video of it functioning?
West Texas Z is offline   Reply With Quote
Old 05-02-2011, 05:42 PM   #7
Aggie Daddy
Thumbs up Re: Installed AVS Shaved Door Kit
Thanks for the info.
Very clean truck, except one problem....that orange color.
A nice Aggie maroon would look great.
I'm just kiddin Austin, TX. A very nice truck.
Aggie Daddy is offline   Reply With Quote
Old 05-02-2011, 10:20 PM   #8
AusTx68
AusTx68's Avatar
Not till the weekend.
And I'm not even a Longhorn or a fan! I just happen to live here but the locals love the color Btw..Go Tech!!
Old 05-04-2011, 11:59 AM   #9
West Texas Z
Old 05-13-2011, 08:45 PM   #10
AusTx68
AusTx68's Avatar
Finally got around to making that video..here ya go!
