Old 06-09-2011, 11:37 PM   #1
awhite4557
awhite4557's Avatar
Russell Quck Disconnect Fuel Fittings
I used the Russell Quick Disconnect Fuel Fittings when I installed the fuel lines in my 5.3 swap. I recently started my PU and the preasure line came off when the pump preasured up. The plastic retainer clip stayed on the fuel rail and the fitting came off spraying fuel all over my engine. Luckily, my engine was cold. If this had happened while I was driving, it could have caught fire. At first I thought the fitting just wasn't seated correctly and re-installed it. It re-installed fine and re-seated correctly and has not come off since but I added a zip-tie to ensure it doesn't come off. I was going to just replace the preasure fitting with a new one and when I checked the LS1 website, I came across a post listing this same problem. It appears this is becoming a common occurance with mostly the preasure side Russell quick Disconnect fitting. Here is a link to that post http://www.ls1tech.com/forums/conver...-fittings.html
As the link states, Russell has a new style fitting that will not come off. The fitting part numbers are 644120 (Summit #RUS644120) for the 3/8 preasure side and 644110 (Summit #RUS644110) for the 5/16 return line.
I called Summit and they did not have the part numbers in their system. They called Edelbrock and got the part numbers and they are in their computer system now but not on their internet catalog. I ordered both fittings and will replace the ones I have on now when the new ones come in, they were on back order and should be here in about a week. Here is a photo of the new fitting.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 06-10-2011, 12:45 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Russell Quck Disconnect Fuel Fittings
they should issue a recall on these, thats a dangerous issue. I have the older style on mine. No issues yet but it hasn't seen street time.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-10-2011, 11:49 PM   #3
awhite4557
awhite4557's Avatar
I agree.
1971 Chevy Chevelle
