Old 05-15-2011, 02:25 PM   #1
SRVBLUES64
issues with correct motor mounts
I have no idea even after reading the forum on 66 mounts for a 350 what to do I have posted a few pics on what i have to see if someone can tell me if my 350 motor and trans will fit on my 66 c10 Please take a look and let me know Thanks again for the help Jeff
SRVBLUES64 is offline   Reply With Quote
Old 05-16-2011, 12:50 AM   #2
Captainfab
60-66 Nut
Re: issues with correct motor mounts
Yep, no problem. You'll just need the motor mounts themselves, and also a trans mount. Bolt the engine and trans together, and set them in as one unit. Once you get the engine located on the motor mount stands, and the bolts started into the mounts, slide the trans crossmember in place. Then once the trans mount is secured to the crossmember, tighten the motor mount thru bolts. Then you can locate and drill the new holes for the trans crossmember.
The motor mounts were used from '63-'72 on the small blocks, and the trans mount from the same year span would work also.
Old 05-16-2011, 08:15 AM   #3
Scot_Douglas
Scot_Douglas's Avatar
Also, when you buy motor mounts, stay away from the $5 models they sell on Summit. I have $10 of Chinese junk sitting on my shelf - junk - because the baseplate is about half as thick as OEM.
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 05-19-2011, 11:03 AM   #4
Real_McCoy
Real_McCoy's Avatar
Glad I read this. I was looking at those yesterday.
Daniel
66 Chevy C10 LWB
Support our troops!
Real_McCoy is offline   Reply With Quote
Old 05-23-2011, 07:21 PM   #5
63 Chevy Stepside
I had the same question about my 63 C10 and found help in this post. Different years, but similar set ups.
http://67-72chevytrucks.com/vboard/s...d.php?t=367487
63 Chevy Stepside is offline   Reply With Quote
