Old 09-15-2010, 11:05 AM   #1
gavinmosher
Wont Fire.... Need any input....
Okay guys i have a 84 chevy swb with a 400 sbc out of like a late 70's c10..... it ran.... i wont say good but it ran about a week ago... well i changed the spark plugs, wires, and tightened the loose rocker it had.... i got it to fire up one time after that and then i tried starting it again and it backfired hard up through the carb and now will not fire to save my life.... it will crank all day, has spark.... not sure if its a strong enough spark but has it on each plug and has fuel..... i rolled it around to what i thought was top dead center and pulled the cap and it was pointed at the number 1 plug wire.... so i didnt think it jumped timing but every once in awhile it will thump on every cylinder like its barley firing and then when you let off the key it will blubber (no other descriptive word sorry) to a stop..... any ideas??? And i do have electronic ignition but the guy at autozone gave me plug wires from a 78 with points... so im at a loss right now guys
gavinmosher is offline   Reply With Quote
Old 09-15-2010, 11:34 AM   #2
Moostifer
a fool with no money
Moostifer's Avatar
Re: Wont Fire.... Need any input....
had the same problem with a 4.3 v6. I replaced...wires,plugs,rotor,cap,module and still nothing (although it had spark) ended up replacing the whole distributor (Oreily's) and never had another problem...
does it have spark to ALL the plugs?
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 09-15-2010, 11:45 AM   #3
nbpro
yup
nbpro is offline   Reply With Quote
Old 09-15-2010, 12:02 PM   #4
jchav62
1962 C-10
jchav62's Avatar
Did you pull the distributor? Sound to me like it's 180 degrees off.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 09-15-2010, 12:11 PM   #5
77 350 Shorty Wide
77 350 Shorty Wide's Avatar
Good Morning, Did you over tighten the rocker? Sounds to me like that may be the cause. If it's an intake valve hanging open that would explain the backfire as well as being 180 degs. out. Are the new wires in the correct firing order?
Good Luck and God Bless, Terry :-)
77 350 Shorty Wide is offline   Reply With Quote
Old 09-15-2010, 12:14 PM   #6
Moostifer
Moostifer's Avatar
Originally Posted by nbpro View Post
yup
so it does... any insight on how to fix his delima?
Old 09-15-2010, 12:45 PM   #7
gavinmosher
lol sorry guys this old trucks about to become a half ton boat anchorweight but its very possible that the rockers could be too tight or loose? what is the easiest way to check if they are too tight.... i did tighten a couple of them but i didnt figure that would cause it not to fire.... im at a loss....
Old 09-15-2010, 12:52 PM   #8
jchav62
1962 C-10
jchav62's Avatar
You want to adjust the rockers when the valves are in the closed position. Maybe try loosening the ones you tighten and see if it fires. Loose valves are better than overtightened ones. I usually like to do valve adjustments with the engine running. I don't think that will work for you at the moment.
Joseph Chavez
Old 09-15-2010, 01:09 PM   #9
gavinmosher
No sir it wont work haha cuz the piece of you know wont even fire
Old 09-15-2010, 01:14 PM   #10
nbpro
cant say that i do didn't no if you seen that or not is all and so maybe you could have more input. but from the looks of it, it may be solved.
Old 09-15-2010, 01:18 PM   #11
nbpro
Now this is confusing. First you said it was firing at all plugs. Now it's not firing. Strange indeed.
Old 09-15-2010, 03:18 PM   #12
irishman999
irishman999's Avatar
Try moving all of your plugs over 1 to the right on the distributor cap.
irishman999 is offline   Reply With Quote
Old 09-15-2010, 04:10 PM   #13
Adams74Chevy
Adams74Chevy's Avatar
...or are you positive the wires are in the correct firing order? I learned that lesson years ago, now I replace one wire at a time to make sure they are in the right order.
2006 Silverado Crew Cab 1500 4x4 5.3L automatic
1986 M1008 CUCV 6.2L Detroit Diesel TH400 4.56 Detroit Locker rear NP208
1973 K20 "Silverado" 350ci, HEI, TH350, NP203 with 2wd conversion, A/C, power windows,tilt wheel, dual tanks. My '73ish K20 thread My 5yo son claims it as his.
1987 V20 Custom Deluxe 350 TH400 NP208 "farm truck" getting parted out.
2016 Nissan Altima grocery getter/commuter
Adams74Chevy is offline   Reply With Quote
Old 09-15-2010, 04:20 PM   #14
jchav62
1962 C-10
jchav62's Avatar
Good point Adam.
How did you replace your wires? One at a time? Did you rip them all out and start from scratch?
Joseph Chavez
Old 09-15-2010, 04:47 PM   #15
irishman999
Faintly circled in red is #1 plug wire.
Old 09-15-2010, 05:44 PM   #16
champions53
Does sound 180 out, Pull dizy out Get it top dead center on intake side this is what gets people the most. If distrubter rotor wont line up corectly after that use large screwdriver to turn oil pump shaft so that it will help in lining up rotor to number one on your cap. Then check your firing order. This has always been my sure fire way to get it right.
champions53 is offline   Reply With Quote
Old 09-16-2010, 12:33 AM   #17
gavinmosher
It has Spark but will not fire.... idk if my termanoligy is wrong but it is sparking but not igniting the gas to start the engine and i have pulled the plug wires 3 times and redone it
Old 09-16-2010, 12:48 AM   #18
77chris03
77chris03's Avatar
1-8-4-3-6-5-7-2 thats ur firing order....should be casted into the manifold. backtrack and "untighten" the rockers you tightened. (back them off a hair) i agree with everyone else that it sounds like ur 180 out.
68 C10 Stepper #1- GONE 68 C10 Stepper #2
1977 Chevy Cheyenne...gone...was my first Chevy
04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD
99 Sierra Stepside, 17 Denali HD, 84 K10
My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333
My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310
77chris03 is offline   Reply With Quote
Old 09-16-2010, 12:51 AM   #19
77chris03
77chris03's Avatar
did you loosen or move the distributor? pull #1 plug out and roll the crank until ur top dead center. check ur rotor to see where its pointing. check ur timing tab and make sure its lined up with the balancer..
Old 09-16-2010, 12:55 AM   #20
77chris03
77chris03's Avatar
Chevrolet / Chevy Engines:
Rotation: Clockwise
Firing Order: 1-8-4-3-6-5-7-2
Old 09-16-2010, 01:26 AM   #21
gavinmosher
okay guys i appreciate the help ill try it on friday i work 6pm to 6am so ill see what i can do..... ill loosen them and try firin it up
Old 09-16-2010, 02:33 AM   #22
irishman999
Did you pull the coil out of the distributor cap?
Old 09-16-2010, 08:04 AM   #23
77chris03
77chris03's Avatar
Damn I didn't see that til now. The pic of the rotation on the distributor is wrong. Just move the 1 to the left and continue cw. Sorry
Old 09-17-2010, 08:08 AM   #24
gavinmosher
Im heading today to loosen my rockers and try to get it to fire.... im gettin frustrated with this old truck.... i wish i knew more about what the previous owner did to the motor
Old 09-17-2010, 10:36 AM   #25
jbeicker
Did you replace the plugs with auto lites? I just had a similar problem and it was caused by the sparkplugs. They looked like they were firing but were not. Another thing to check is power to the distributor. Make sure you have about 12.5 volts. You probably do not if you have been cranking on it for a while.
jbeicker is offline   Reply With Quote
