425hp409
![]() Join Date: Oct 2008
I am installing 72 disc brakes and spindles from a 72 onto a 66 but have run into a ball joint fitment problem. What ball joints, it any, can I install in the 66 control arms and use the 72 spindles?
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
![]() Join Date: Sep 2006
Re: 72 disc Brakes on a 66 C10
I think the 72 ball joints work in the 66 arms.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
60-66 Nut
If the '66 is a C10, the '72 ball joints should fit no problem. If the '66 is a C20, then you have a problem. I don't know if there is a lower ball joint that will fit the LCA and the spindle at the same time. if it is a C20, have you tried the '66 ball joint? A '73-'87 C20 ball joint, The '88-'98 light duty 2500 ball joint? If worse comes to worse, you might have to go with a ball joint that is too big for the spindle, and have the taper on the spindle enlarged with the proper reamer.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 06-01-2011 at 01:10 AM. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Outer tie rod will be different also.
More info here: http://67-72chevytrucks.com/vboard/s...57&postcount=3
![]() Join Date: Aug 2004
I have installed the 72 c10 discs on my 65, didnt have an issue other than outer tye rods like said.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
