Hi, do the wires from the plug get attached to the fuse block. For example, the temp sending wire gets attached to the temp wire on the plug. Does the amp gauge wire go the alternator. Need suggestions. Thanks
Robert Olson Transport
![]() Join Date: Oct 2002
Re: 73 gmc cluster gauge plug
this may gather more responses in Electrical . Please let me know if you would like me to move it.... i have no idea as to the correct answer on this one
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Hi Rob, found the answers. Thanks
Looking for same info, Where did you finf it?
dfleming7- i compared my old fuse box setup to the wires coming from the plug and followed each wire on the cluster gauge film diagram. I am installing a new 21 circuit Ezwiring fuse box. They have stamped wires coming from the new fuse box. These wires get connected to the senders, like the oil sender. The cluster plug is numbered on each side and identifies each wire. Follow each wire on the diagram to their specific gauge. The wires coming from the plug are connected to the fuse box. In your cluster you have amps, oil, temp, gas and maybe a tach. I have a clock which gets connected to a spade in the fuse box for power. Hope this helps. classicGMC73
