Old 06-03-2011, 11:30 PM   #1
ECU PIRATE
ECU PIRATE's Avatar
Transmission crossmember interchangibility
What year transmission crossmembers are interchangable? I threw my old one from my 82' out because of the PO's hack job and picked up one from 87' dually burb (off of his 90' Burb).
Tried to put in in tonight and it's not even close to fitting. Any ideas??? Am I going to have to drill some new holes to install the one I got from Chris or get one from another 81'-82'? Can not put the motor and Muncie in with out one. I knew I should have kept that old crossmember!!!!!!!!!!!!!!!!!!!
Here is a pic of where the part that mounts to the underside of the top of the frame is mounted. Is this the correct position for a TH350 or a Saginaw 3 spd? What I pulled out of there was a Olds TH200 and the PO had to notch the crossmember for the tranny pan to clear.
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 06-04-2011, 06:35 PM   #2
ECU PIRATE
ECU PIRATE's Avatar
Re: Transmission crossmember interchangibility
Anybody?? I know someone has the answer. I am gathering there wad s cross member Change in the mid 80's. One of you guys chime in who have done the auto the manual swap. Anybody made their own cross member or modified one?
The Fleet........
Old 06-04-2011, 07:18 PM   #3
b454rat
I didn't know there was a x-member change, but would think that any 2wd would work or be close enough to modify??
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 06-04-2011, 08:21 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Early ones without a cat leave the most room for dual exhuast. Im using one from a 3/4 ton. It requires some fab work for a 1/2 ton though.
Old 06-04-2011, 09:00 PM   #5
russgt
russgt's Avatar
This what my 76 blazer has. I pulled an identical one out of a 80 3/4 with a turbo 350/205. Did the crossmembers change when they went to aluminum transfer cases?
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 06-04-2011, 09:20 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
ECU 2wd or 4wd
Old 06-04-2011, 09:57 PM   #7
russgt
russgt's Avatar
my bad, I think he is looking for 2 wheel stuff
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 06-05-2011, 08:53 AM   #8
my4by2
my4by2's Avatar
Just dump the ugly factory crossmember & build your own (or have it built) like on my truck. It'll be better all the way around!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 06-05-2011, 11:43 AM   #9
ECU PIRATE
ECU PIRATE's Avatar
Here is where we are at this morning
The Fleet........
Old 06-05-2011, 12:03 PM   #10
ECU PIRATE
ECU PIRATE's Avatar
Another shot. The holes to mount it to the bottom of the frame are about 1" shy of making it........ I guess I will be going to the pick and pull because this 90' Burb cross member will not work
The Fleet........
Old 06-06-2011, 09:19 AM   #11
ECU PIRATE
ECU PIRATE's Avatar
Here are some shots of the one I took out. Looks the same but, I just can't figure out the problem
The Fleet........
Old 06-06-2011, 03:08 PM   #12
ECU PIRATE
ECU PIRATE's Avatar
Maybe I just foound my answer or at least as couple of different directions to take.......
http://67-72chevytrucks.com/vboard/s...d.php?t=307481
The Fleet........
Old 06-08-2011, 07:11 AM   #13
ECU PIRATE
ECU PIRATE's Avatar
Finally wrestled it in last night. Still need to do one bolt on the bottom of the driver's side of the frame and the two on the bottom of the passenger side. had to break out the 2 ton floor jack to make it happen. Might need to break out the 5 pound hammer to get it snug............
The Fleet........
