Add to fan shroud or use fan spacer
I am looking for ideas on what to do with my Suburban. It has a 454 4 row rad and shroud with a 350 engine. Due to this the fan isn't far enough in the shroud. I can't use most fan spacers, as they are meant for flex fans that don't have a clutch. Anyone know of a spacer meant for clutch fans?
Or, I was thinking of maybe adding a strip of aluminum around the shroud to make it deeper, but don't know where I would even look to be able to get something like that.
1995 Suburban K2500 454.....off road & towing 1999 Astro, work van 2006 Silverado 2wd 5.3 w/4.5" lift and 33s Last edited by TheApocalyptican; 06-17-2011 at 03:22 AM. |
#2 | |
Old Heap Driver
Re: Add to fan shroud or use fan spacer
A picture or two would be helpful, but if you can't I understand. Aluminum pieces can be found at Lowes or Home Depot. How far into the shroud is your fan?
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
I have the exact same set up on my C10.. Hayden makes a 1in fan spacer that put the fan 1/2 in and 1/2 out of the shroud. I noticed a huge difference in cooling on the gauge and a/c efficiency after i installed it.
jeff
Jeff 1986 Chevy C10 Custom Deluxe swb 1983 Chevy Silverado swb stepside, factory 6.2/700r4 2002 GMC Sierra SLT 1979 GMC Jimmy High Sierra 1978 Chevy C10 Big 10 lwb Scottsdale |
#4 | |
Right now the fan is maybe 1/32" to 1/16" into the shroud.
1995 Suburban K2500 454.....off road & towing 1999 Astro, work van 2006 Silverado 2wd 5.3 w/4.5" lift and 33s |
At the body shop.
Studs in the water pump?
" That didnt make it any newer " " Dont antique the equipment " |
Not sure if you're maybe asking about trying it that way?
Currently, there are studs in the water pump. About 1/2" worth that threads into the pump, and about 3/4" worth that are what are used to bolt the pulley and clutch onto. My only concern with the studs is being able to find some that have the flared out un-threaded part with a longer threaded portion on front.
At the body shop.
Yeah get longer studs for the spacer. Fastenal oughta have them.
