Old 06-27-2011, 01:29 PM   #1
riciano
tandem lock
I just bought a 1963 c-10 and it says "tandem lock" on the dash, what's this for?
riciano is offline   Reply With Quote
Old 06-27-2011, 02:33 PM   #2
blackedoutharley
Re: tandem lock
Chevy used the same basic dash cluster for all trucks. The Tandem lock and Overspeed lights weren't used in the smaller trucks.
blackedoutharley is offline   Reply With Quote
Old 06-27-2011, 02:43 PM   #3
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: tandem lock
My guess is that your instrument cluster gauge came out of a tandem axle truck. (Dump truck or such). Might of been switched out at some point in its life with a gauge from a big truck. A tandem axle is a group of two or more axles situated close together. Trucks designs will use such a configuration to provide a greater weight capacity than a single axle.
http://www.davegrahamautoliterature....op_Manual.html
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 06-27-2011, 02:48 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Re: tandem lock
Other web posts indicate the Tandem Lock light is an indicator for a two speed rear axle found in C60-C80 trucks.
Old 06-27-2011, 02:54 PM   #5
1Bad62Pro/Street
Lightbulb Re: tandem lock
Ahhhhh....
I see now.
http://www.stovebolt.com/ubbthreads/...45743&page=all
Old 06-27-2011, 03:02 PM   #6
oldtrux
oldtrux's Avatar
Re: tandem lock
i agree the gauge cluster came out of a larger tandem axle truck.there would be a switch on the dash (sometimes an air switch)to lock up the tandems,like 4 wheel drive if you will.highway tractors still have these switches today.helps you get out of some nasty situations,mud snow or even if you get hung up on a steep driveway incline or something and the front axle is off the ground and whheels are spinning inthe air,hit the switch and the rear axle locks in and away you go!
oldtrux is offline   Reply With Quote
Old 06-27-2011, 03:49 PM   #7
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: tandem lock
the clusteer is probably original to the truck, on the smaller trucks the tandem lock and overspeed indicators just wern't lit up...
Old 06-27-2011, 04:32 PM   #8
jocko
jocko's Avatar
Re: tandem lock
Concur with jonz - I believe all dash clusters were the same and you only got the switch, etc if you actually had a tandem truck.
Here's what I did with my tandem lock indicator...
http://67-72chevytrucks.com/vboard/s...d.php?t=419932
Old 06-27-2011, 04:40 PM   #9
riciano
Re: tandem lock
Thanks everyone. I know everything's original on my truck, it had set-up on blocks in a barn for over 30 years. I used to have a '66 and knew that it didn't have a tandem gauge on dash, so it surprised me when I saw that this '63 did have one. Do all '63 models have them on the dash?
Old 06-27-2011, 04:57 PM   #10
SFTorange
SFTorange's Avatar
Re: tandem lock
The tandem lock light came on small trucks with the factory gauge style clusters. Trucks that came from the factory with warning or "dummy" lights didn't have the tandem lock light option.
SFTorange is offline   Reply With Quote
Old 06-27-2011, 05:00 PM   #11
riciano
Re: tandem lock
Thanks for all the replies.
