Old 06-26-2011, 03:28 AM   #1
iehotrod
iehotrod's Avatar
Calling on you brake experts
Need help!! I bought a set of front spindles,rotors and claipers from a local. They were on his 64 c10 and I would like to install on my 62 c10. I know 60-62 is the same and 63-70 is different. what is the difference???
iehotrod is offline   Reply With Quote
Old 06-26-2011, 06:48 AM   #2
blackedoutharley
Re: Calling on you brake experts
60-62 had torsion bars and 63 + has coil springs.... I don't know if the late model spindles will work on a 60-62 but somebody will be by today that can answer that.
blackedoutharley is offline   Reply With Quote
Old 06-26-2011, 08:22 AM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Different balljoints; you could do a crossmember swap and use the parts.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-26-2011, 11:24 AM   #4
A.T. RockDriller
A.T. RockDriller's Avatar
Hey iehotrod.....
Wow, as far as the brake thing, I know that the '63's on up had.....
Oh....$hit.....
I thought you said "BROKE experts".
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 06-26-2011, 12:10 PM   #5
iehotrod
iehotrod's Avatar
I don't think I would change the cross mamber for a 63 or newer suspension and disc brakes. At that point I would rather pick up a junked 73-87 newer c10 and do a complete swap including the rear end and convert to the 5 lug. with power steering.
If it all it is, is just ball joints that should be easy. I think...
Old 06-26-2011, 12:32 PM   #6
protrash64
protrash64's Avatar
I did the reader's digest version.........balljoints and control arms are completely different design. You could have the spindles machined to fit the 60-62 bj's I suppose......or sell the spindles and get one's for 60-62 and use the rotors and calipers. These are the only options coming to mind at this time.
Old 06-26-2011, 01:03 PM   #7
Clyde65
Clyde65's Avatar
arent the 60-66 frames wider than 63-66? I know the rear frame is wider on them, just wondering.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is online now   Reply With Quote
Old 06-26-2011, 01:23 PM   #8
Bugeyev8
Bugeyev8's Avatar
Nope not up front, the x member will bolt in but needs a few more holes drilled, I think it was like 4 holes needed to be drilled
Bugeyev8 is offline   Reply With Quote
Old 06-26-2011, 01:36 PM   #9
iehotrod
iehotrod's Avatar
Thanks ProTrash64, it may be what I'm going to do.... I might just end up selling the whole set up I dont know. We'll see..
