Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-08-2017, 03:16 PM   #1
Couch
Daily Driver
Couch's Avatar
trailing arm crossmember location
I posted this in suspension, got views, but couldn't get a response. just wanting a little reassurance.
I recently purchased a porterbuilt trailing arm crossmember and am planning on backhalfing my pickup with the chris alston battle cruiser kit but I will be remaining trailing arm. my question is, it is currently a 72 longbed frame- if I remove the factory TA crossmember and install the PB fab one a foot further towards the front, then lop off the frame behind it and weld in the back half, that will essentially leave me with a shortbed wheelbase correct? just want to be sure from all of the posts that ive read.
nitrous...the equal opportunity destroyer.
Couch is offline   Reply With Quote
Old 01-08-2017, 11:59 PM   #2
Captainfab
60-66 Nut
Re: trailing arm crossmember location
Yes, moving the trailing arm crossmember forward 12" will give you a 115" wheelbase. Before you weld the PB TA crossmember in place, be sure you have sufficient room to weld and reinforce the backhalf to the frame.
Old 01-09-2017, 01:03 AM   #3
Couch
Daily Driver
Couch's Avatar
thank you, i had read quite a few posts on here and had a pretty good idea, but the reassurance from you is very appreciated.
Old 01-13-2017, 10:10 PM   #4
c10-72 II
Active Member
c10-72 II's Avatar
Are you going to make a build thread? I'd sure like to see how you do it. Always wanted to backhalf my c10.
1972 GMC C2500 Tow Rig project
1972 C10 Air Bag project
1967 C10 Drag Truck project
1967 GMC Patina Special project
1968 C10 I have no clue what to do with project
1969 GMC C6500 I wish I had more money project
1986 K10 I have too many damn projects
c10-72 II is offline   Reply With Quote
Old 01-30-2017, 12:19 PM   #5
Couch
Daily Driver
Couch's Avatar
yeah, i will be doing a build thread going here soon. still accumulating some parts that way its not too strung out and i can hammer alot of it back together at once.
