Old 06-05-2011, 05:48 PM   #1
gotchamel
window regulator?
Passanger side on my 69 c10 is alittle sticky.Never have fooled with a regulator before,any suggestions other than pay attention to how everything is assembled?Is the regulator itself the most common culpurit?Thanks.
gotchamel is offline   Reply With Quote
Old 06-05-2011, 08:11 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: window regulator?
probably being 40+ years old, needs a little grease....this might help ya....http://67-72chevytrucks.com/vboard/s...d.php?t=157539
Also, if you haven't purchase one, I'd recommend a factory assembly manual as well....
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-05-2011, 09:39 PM   #3
Sammy
After all these years of abuse I agree most of the orignal regulators are shot. Little tricky for some to replace others don't have any problems what so ever. Find you a decent replacement regulator and go for it.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 06-06-2011, 05:38 PM   #4
gotchamel
Would LMC be a good source?Thanks.
Old 06-06-2011, 05:41 PM   #5
Fldawg
Fldawg's Avatar
i put one in from brother's and it worked great and that was with the one piece window conversion
Fldawg is offline   Reply With Quote
Old 06-06-2011, 05:57 PM   #6
Sammy
I almost always use a board vendor for new parts then if something isn't right they are more likely to make it right plus they support this board.
Old 06-06-2011, 06:01 PM   #7
gotchamel
Makes good sense,dance with the one that brought you,right?
Old 06-06-2011, 06:46 PM   #8
Fldawg
Fldawg's Avatar
brother's is a supporter of this site
Old 06-06-2011, 06:50 PM   #9
cdowns
cdowns's Avatar
it's alot cheaper to take off inner door panel and spray with lubricant and work the thhing slowly up and down while spraying // lots of times that is all that is required to get a moving part working is clean and lubricate
Old 06-06-2011, 08:08 PM   #10
Fldawg
Fldawg's Avatar
lube , won't fix worn out
Old 06-06-2011, 08:44 PM   #11
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
If it is just a little sticky it could be your weatherstrip, and not the regulator. The lower sill will catch on warn out weatherstrip and make it sticky feeling. So look at that also. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 07-15-2011, 05:27 PM   #12
gotchamel
Ordered a regulator,tool,pivot and screws and extra clips today.Its hot and I gotta get that window working.Will tackle it when parts arrive.Thanks for the info.
