Always a work in progress
HD brakes vs standard brakes
What year did the 1-1/4" brake rotors come on?
I am converting the the thicker rotors up front and Summit has some Brembo rotors on clrearance but it doesn't say if they are 1" or 1-1/4". The application guide says it is for 71-74 C10 Pickups and 75-86 C10s. I called them and they don't have any extra information other than what is on the website. When did GM go from 1-1/4" to 1"?
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
Re: HD brakes vs standard brakes
part number is BRE27016
I think they went to them when the Square '81 front ends came out, because the 81+ i see in the scrap yard are the skinny rotors..but I'm not certain this is the case
Were the 1" rotors available on the 79 and older trucks or did they all come with 1-1/4" rotors?
I don't believe 1" rotors came on these trucks until the 'metric' years so around 1981. Before then 1.25".
I ordered them and if they aren't 1-1/4" I will just return them. $25 a piece was the cheapest I could find anywhere.
