pinion angle question
I know this has been covered but I'll ask. In the photos below you will sort of see the pinion angle I have. I have installed a 2" lowering block and coils from an El Camino that should net me around a 5"+ drop. I flipped the trailing arm brackets to correct the pinion angle and now (without the bed or fuel tank in place) I have a slightly upward angle. I think it will work out but I'd like some experience opinions. I am thinking I'll wait until I get the bed on and a fuel tank (or simulated weight) and recheck the pinion angle. At that point I can either fab up some different brackets or install shims. So waddya all think?
2WD Jimmy
![]() Join Date: Mar 2005
Re: pinion angle question
I would flip the cross member back over and use shims 'if' you need to.
![]() Join Date: May 2007
Absolutely have the actual weight on it, when setting up the angle.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
C/10 junkie
Ok I found this on another thread.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
Thanks Shawn. With that and some research it looks like the ubber cool trailing arm bracket flip is not a good thing to do. Should have thought that one out a bit and I would not have wasted my time with it...but things are cleaner down there now. Basically my pinion gear/shaft center line needs to match my transmission center line and let the secondary drive shaft do it's work. Hmmm...
C/10 junkie
![]() ![]() Join Date: Jan 2011
Yes, it looks like the pinion is up a little higher than it needs to be. I usually try to run about 1deg down at the pinion. You don't want to completely zero it out or it will not have proper lubrication in the Ujoint cups. 1-2deg and you'll be fine.
Weight the rear end with what you'll have at finished ride height. Just eyeballing it I would suggest running 3 or maybe 4deg shims.
#9 | |
Before you go and swap everything back around, measure the angle at the trans and at the rear.
![]() Measure it at ride height and be sure. If you flip it back your driveline will be working as if it were stock, bottomed out condition 5"+ drop and worse when you put anything in the bed.
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper |
#11 | |
1 gallon of gas = 6.15lbs @ 68 degrees.
so, 15 gallon tank = roughly 92lbs. My point is you could simulate the weight. It will be easier to shim the rear with the tank out of the way. Just a thought.
