Old 08-04-2011, 08:53 PM   #1
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Water comming in under the dash
Ive been having to use the Burb the past couple days after our Toyota was crunched by a semi on our way to Texas last month. So, Ive had to drive it in the rain a couple times. I have water running in on both sides INSIDE of my truck under the dash. Where the heck is it comming in at? Has anyone else had this problem?
junk
"The unexamined life is not worth living" -Socrates
'71 GMC Suburban 4x4
GMCjunkie is offline   Reply With Quote
Old 08-04-2011, 08:58 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Water comming in under the dash
inner cowl area is rusted/rusted thru, maybe bad windshield seal..
John
1999 Toyota Tacoma 4x4
Old 08-04-2011, 10:47 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Water comming in under the dash
Bad gasket around windsheild. Comes in the lower corner then drips down through the drip hole on each side of the dash. You can seal the gasket up with a good sealer but a good windsheild man want need to!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-04-2011, 11:20 PM   #4
gonnuts
gonnuts's Avatar
You can seal the gasket up with a good sealer but a good windsheild man want need to![/COLOR][/B][/QUOTE]
Ya what he said ????
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4
gonnuts is offline   Reply With Quote
Old 08-05-2011, 11:38 AM   #5
bosco200
bosco200's Avatar
Originally Posted by andy4639 View Post
bad gasket around windsheild. Comes in the lower corner then drips down through the drip hole on each side of the dash. You can seal the gasket up with a good sealer but a good windsheild man want need to!
x2
bosco200 is offline   Reply With Quote
Old 08-05-2011, 07:04 AM   #6
eagleuh1
eagleuh1's Avatar
I had 2 pinholes, actually bigger than pinholes, in the cowl floor from leaves sitting in the cowl. Found them one day working under the dash looking up and saw 2 streams of sunlight coming in. Sanded them down, but couldn't get tig torch in to weld. I used some of my sticky sound deadening on the inside of cab to seal up temporarily. Works so far ( 1 year). On another note, why do our dashes have drip holes on each side?
eagleuh1 is offline   Reply With Quote
Old 08-05-2011, 07:31 AM   #7
72freak
Rottenwood Garage Member
72freak's Avatar
I would first take the cowl off and look under there. I bet thats where its at.
The way I test is I get someone to lay in the floor and I fill the cowl with water and see if it leaks.....It may take a while.....if I dont see any water I then broaden my water placement to the top of the windshield and let it run down. If it starts to leak its the gasket.
2004 Chevrolet Suburban C1500
2001 Chevrolet 2500HD Crew 6.0
1999 Harley Davidson Electra Glide
1972 Chevrolet C-20 Custom Camper "Dump Truck"
1972 Chevrolet C-20 Suburban "Big Green"
1969 Chevrolet C-50 Wedge Hauler "Leonidis"
1966 C-10 2x4 short fleet 327 4 speed "Race Truck"
1952 Plymouth Cranbrook "Rican" (my grandfathers)
1931 Ford Model A Coupe "Black Beauty"
1930 Ford Model A truck "Club Cab" 4x4
Rottenwood Garage and Speed Shop.....where everything must be racy!
It's not just a hobby..It's a LIFESTYLE!!!
Thanks for nothing Barrett-Jackson
You cant fix stupid or teach accountability!
Time wasters, looky Lous and tire kickers are everywhere!
72freak is offline   Reply With Quote
Old 08-05-2011, 08:19 AM   #8
GMCjunkie
Dude...I'm a CHICK
GMCjunkie's Avatar
Thanks guys, figured it might be the cowl, but I just got it out of the shop and any rust holes were "supposed" to be fixed, but then so were a lot of other things. Also, Their glass guy broke my windshield putting it back in, (HE broke it and charged ME for a new one),so mabey Mr. Professionalglassguy didnt seal it good. Ill try 72freaks system.
THANKS!!!!!
junk
