Helper bag kit
Hey guys, need a little help. I'm looking at putting in some help bags just so I have extra support when pulling our boat. I've seen a number of posts with guys doing the same.
I know they don't make a specific kit for the 72, but what kits are you using? I contacted Jegs and they said they don't have a kit. If you have a specific part number, that would be greatly appreciated. THANKS! |
#2 | |
Re: Helper bag kit
69 Chevy 4x4 383 Power ![]() |
What?
Re: Helper bag kit
I have a set that I took out of a 67 leaf sprung burb.
Don't know who made them, but they don't look at old. So, they are out there.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Re: Helper bag kit
Trailing arms. No leafs.
Re: Helper bag kit
Did you look at the Air Lift 1000 in the link I posted above. It fits open coils and is only $90
Re: Helper bag kit
Just swap bags in place for the rear coils. Leave them @ 30-40psi unloaded & add some air via a simple schrader valve set-up when you plan to load it down. You would be purchasing 2 bags regardless right?
Re: Helper bag kit
If you go this route you may want to consider adding a rear anti sway bar.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() |
