Old 08-06-2011, 06:08 PM   #1
72longbed
72longbed's Avatar
Question How To Get A 72 K20 To Handle/Corner Well ...
Here's a "what if?" What if you had a 72 K20 4x4 longbed with a 4" Tuff Country spring lift, LT285/75R16tires ... and you wanted it to handle and corner as good as a pickup truck could?
Would it be necessary to:
1. remove the lift
2. use lower tires?
3. change to some other aftermarket spring packs?
etc., etc.
Just thought I would start this thread and see who has some experience with getting their 67-72 4x4 to really handle well?
Thanks for your opinions.
72longbed
72longbed is offline   Reply With Quote
Old 08-06-2011, 06:30 PM   #2
snj8198
snj8198's Avatar
Re: How To Get A 72 K20 To Handle/Corner Well ...
I have a Tough Country EZ ride 2 inch lift with 315/75R16's. Installing a swaybar helped considerably to lock the sway down. Tho not a race car, it does feel significantly more comfortable driving through the Montana mountain curves at speed. I plan to step up to 17" rims so that may help too by taking some of the sway out of the sidewalls. Making sure all your suspension bushings are in good shape really helps as well.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 08-06-2011, 10:22 PM   #3
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
There is really no comparison on handling between a lifted truck vs a stock height truck. The taller vehicle has a higher center of gravity and is therefore at a disadvantage. A lower truck with a tight suspension and shorter sidewall will always prevail, all other things equal.
One of the things I've come to terms with whenever I work on a truck is to remember to keep things relative. I'm not expecting a soft ride, great gas mileage, sport car handling, etc. I know this doesn't answer your question, but to me, I just try to put things in perspective.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 08-07-2011, 02:41 AM   #4
OldCreek
OldCreek's Avatar
Set up a sway bar system? Maybe with disconnects.
Cross over steering
Stiffer side wall tires
New polyurethane body mounts
Just thinking out loud.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 08-07-2011, 11:22 AM   #5
vectorit
What?
vectorit's Avatar
The best thing I have done in the past for making a 4x4 truck handle better on the road, is the best shock absorbers you can find along with proper springs and poly bushes.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-07-2011, 11:47 AM   #6
72longbed
72longbed's Avatar
Thanks to all so far. Any pictures/info on front and rear sway bars for a lifted 67-72 4x4? I think I looked into this years ago and there weren't any options other than custom fabbed jobs.
I understand the dynamics difference between lifted vs. stock .... just trying to 'tweek' the best performance from what I got.
Thanks.
Old 08-07-2011, 08:46 PM   #7
Billhilly
Billhilly's Avatar
This was one of the brief's when I started on my truck.
So by default (RHD) I went to a variable ratio steering box with cross over steering. Long travel Bilstein shocks, front and rear sway bars, and would like to add air bag assist in the future. Can't tell you how any of this worked out handling wise cause that is still in the future too!
Oh, 2" lift springs, new bush's etc. Rear disc conversion, Yellow Stuff Pads. Ahh, stuff like that. Pic's, build here - http://67-72chevytrucks.com/vboard/s...d.php?t=217490 Sway bar info around post #61.
'73 and up front bar fits doesn't it? Add some ORD disconnects. Some for sale on here. Have never seen a picture of a rear bar on a 4X4.
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 08-08-2011, 12:13 AM   #8
snj8198
snj8198's Avatar
Any front 1&1/4" sway bar for a 3/4 ton Chevy will work as they bolt to the front spring mount clamps, but you will have to make your own braces to the cross member. I used a chunk of 2x4 square tubing and cut it to fit the contour of the crossmember. Then ordered a set of brackets with poly bushings from Wes at Classis Heartbeat (thanks Wes). Worked slick. The before/after feel of the handling was significant.
-steve
Steve
Old 08-08-2011, 08:19 PM   #9
onebadbowtie
onebadbowtie's Avatar
here are front and rear sway bars for 67-72 4wd trucks.....
http://www.sdtrucksprings.com/sway-b...k/pickup-63-87
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 08-08-2011, 08:28 PM   #10
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I am going to put front and rear sway bars on my Longhorn. Eventually. I have them on my 95 F-350, which has a 4" lift and 33's. It drives as nice as my stock suspension 05 Dodge did. But, I built some heavy duty end links for my sway bar. On my Longhorn I'm planning on using a sway bar from a first gen dodge to be able to bolt to my axle. The rear might be from a ford. Good shocks is a must like already mentioned.
Ryan
1969 Chevy milk truck
Old 08-08-2011, 09:00 PM   #11
snj8198
snj8198's Avatar
I guess i forgot what diameter the swaybar was.
Steve
Old 08-09-2011, 11:41 AM   #12
I've always felt my lifted 4wds have handled/cornered really well. I'd think a 4" lifted truck with 285/75s would corner really well. Leaf spring/solid axles give far less body roll than independent suspension. And,lift kits are generally stiffer than stock. I enjoy putting distance between me and the sporty car behind me on cloverleafs and tight turns. It's true the center of gravity is higher,but when you go to 12.5" wide tires on 10" wheels you also ad to the track width and they come close to canceling each other out. You need to be careful,but I find they handle great.
Old 08-11-2011, 09:08 AM   #13
racin69z
racin69z's Avatar
I'm with special K. I had 6" superlift heavy duty springs (log wagon ride, but no body roll) with rs5000 shocks and 35 12.50 tires when I drove my truck every day. I could push it hard through the corners at highway speeds, and it would start to 4 wheel skid before it felt like it was going to roll. It would really scare the heck out of people who had never rode in it before.
The truck always tracked straight too. I had it well over 100 mph a couple times on the 35's and could have drove with 1 hand on the wheel.
I think a stiff suspension, tight ball joints, tie rods, and drag link are important. As well as the proper steering correction for the lift. In my case I had the 4-6" steering arm.
Lynn
racin69z is offline   Reply With Quote
