Old 03-19-2002, 11:06 PM   #1
1969lb
Post just out of curiousity
how much can i get for a just rebuilt 305?
it was magna fluxed,hot tanked and honed
new rings,new crankshaft oil pump quadrajet manifold and carb.rebuilt heads etc.
i can sell put together or not im trying to pry this truck off an old lady and its got a 350 well i dun nd the 305 so im going to nd bargaining money......
its been sitting in her yard since 86
72swb/stepside no rust perfect body 100%rust free cab only 2 dings in the entire body.
hmm...looking for a swb frame with disc brakes
1969lb is offline   Reply With Quote
Old 03-19-2002, 11:18 PM   #2
69LWB3/4Ton
Post
I'll start the bidding at 15dlrs
69LWB3/4Ton is offline   Reply With Quote
Old 03-19-2002, 11:21 PM   #3
Mike C
Mike C's Avatar
Post
I've got 2 running 305's and know 3 other guys who have them as well. Free for the taking. Can't give a 305 away around here. Literally.
70 GMC 3/4 ton Sierra Grande 402/TH400
72 Jimmy 4WD 4spd 4" & 35's
64 Corvette Coupe
68 Camaro 'vert TPI & TH700
69 Z/28 355 12.6's @110
72 Datsun 240Z-ol' reliable
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
02 GMC 2500HD 4x4 Duramax
Old 03-19-2002, 11:25 PM   #4
72gmc1/2ton
Post
I BELEIVE THAT THE 305 LIKE 307 (WHICH I HAVE) ARE GUTLESS WONDER AND JUST SUCK DOWN GAS.
72gmc1/2ton is offline   Reply With Quote
Old 03-19-2002, 11:45 PM   #5
imdarren
imdarren's Avatar
Post
1969lb, WoW! It's not soundin' like what ya wanna hear. Not good at all... I rarely hear anything positive about the Chevy 305 either. I hope you work somthing out for the 72 though! Sounds nice! Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 03-20-2002, 12:06 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
How honest are you? You could try to pass it off as a 350...you always here bout someone gettin a 350 only to discover it's a 305. I'm not recomending it...
You could also find something that just needs a small block, slap that sucker in there, and sell it. Like maybe...an S-10.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
Need to pick up the one ton Longhorn with a PONTIAC 350/350soon.
Thanks every one!
Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 03-20-2002, 12:36 AM   #7
69 longhorn
Post
305s dont run too bad in a small truck,I have one in my 89 Ranger.....kinda rattles the ford boys too!........69 longhorn
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 03-20-2002, 01:12 AM   #8
Fast68Chevy
Fast68Chevy's Avatar
Post
i had a fresh rebuilt 1980 caprice 305 with original stockl aluminum intake manifold and rebuilt roch q jet in my 68 c10 with 3 speed and then th350 with the 3,73 rear and it was nice !! it moved right alont wayyyyyyy better than the 307 it replaced. i had no complaints at all, i later put 1.94 int valves and edelbrock springs on it and vroom vroom was more fun, wasnt doggy one bit a tall, it all just depends on the condition of the engine, 307 would have been same way had it not had 200,000 + miles on it and the snapped and bent over the #1 piston rod and also spun other bearings
if it runs good then use it, all it is is an anemic 350, 305 are good dem derby engines and spare engines to get tou by when 350 blows up
cant rag on it if it runs good,
Fast68Chevy is offline   Reply With Quote
Old 03-20-2002, 01:25 AM   #9
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Post
the only part of a 305 that's any good is the heads, you can use the intake on other small blocks too, but everyone as 3 of those. In my area, you can get 100 bucks for a set of heads. The stock car guys like them for the added compression on a 350.
'72 Chevy 1/2T 4x4 shortbox stepside 350/350auto on '84
ralleys and 31/10.5s
67 Cutlass convertible
330, 3spd stick
90 GMC Jimmy
350/auto
Chad Stephens
Orleans,NE
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 03-20-2002, 01:41 AM   #10
67 cst swb
67 cst swb's Avatar
Post
I hear the Navy is buying surplus 305's
...They work good for boat anchors...
just kidding...
Bryan in So.Dak
Bryan in South Dakota
-67 CST(CE147J122461)327-4bbl(missing) w/TH400 w/AC,PS,PB,3pc bench/bucket seat,small window,LWB. orig. blue/blue. needs serious restoration
-67 CST(plain janer) 283/MT LWB ---soon to look like 68 with 350/TH350 ShortWide Box
-2000 Silverado 1/2ton 2wd x-cab w/4th door
***future projects***
A 67/68 CST,SWB,350/TH350,Lowered 5/7, rollin' on 17's, not air bagged.using above listed 67 CST (janer)
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red
67 cst swb is offline   Reply With Quote
Old 03-20-2002, 07:38 AM   #11
Longhorn Man
Post
The 305 heads will bump up compression, but they are so restrictive you can actually hear the air stacking up in it where it can't get out as fast as it goes in.
Thanks every one!
Old 03-20-2002, 07:53 AM   #12
71GMCstreet
Post
The 305, no-matter-how you build them are doggy at best. I have 2. One in the street rig, and one in my 98. The oldie looks great under the hood and is carbed. The newbie is computered and SUCKS!!!! I hate the throttle response and de-acceleration. The street rig is crying to have a bigger motor in her, and I hope later this spring she'll get her wish.
71GMCstreet is offline   Reply With Quote
Old 03-20-2002, 08:00 AM   #13
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Exclamation
Nothing wrong with the 307's. Everyone I had/have serve me well.
63 Impala*66 Chevelle SS*69 Chevelle*69 C10 Stepside*71 Cheyenne 20*72 Chevelle
Parts for sale:
http://www.angelfire.com/trek/mr409/items4sale.html
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 03-20-2002, 02:18 PM   #14
sam's 72
Post
I he a 305 in my 72 lwb right now, and I am replaceing it with a 383 sbc, and I already have some one that wants the 305 for a jeep, and I am just giving it away!
sam
72 LWB chevy truck.
Pasadena, Texas
sam's 72 is offline   Reply With Quote
