Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-19-2013, 12:13 AM   #1
lurch115
lurch115's Avatar
Bolt it on or sell it?
so a few weeks ago I acquired an interesting setup and have been going back and forth on weather to bolt this setup on and try it out, or just to sell it.
Reasons why i am hesitant to bolt it on are #1. the motor is already a .060 350cid(4 bolt main with a forged steel crank) running atleast 10.5:1 and #2 throttle linkage fitment.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 11-19-2013, 02:28 AM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Bolt it on or sell it?
I always wanted a set up like this with a Q-jet just to tryout and play with . I think it's cool . If it were mine i would try it on something for sure .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 11-19-2013, 03:15 AM   #3
BigDan3131
BigDan3131's Avatar
That looks like that turbo setup used on the 301 Pontiac motor...
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 11-19-2013, 05:42 AM   #4
hotrod 80
mini truck racer
hotrod 80's Avatar
Similar , but for a sbc . I have also seen some that have a sort of split manifold under the carb with the turbo to one side non intercooled . Pulls through the carb and out the rear of the adaptor . then is compressed . Then pushed through the front of the adapter . The Pontiac deal had the carb on an adapter on the turbo mounted to the driverside if i remember correctly .
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 11-22-2013, 01:30 AM   #5
lurch115
lurch115's Avatar
BigDan it's actually a setup made by A.K. Miller. From what i have read he did alot of salt flats racing. This setup is actually a draw through setup, and puts the carb. up beside or just ahead of the alternator. It was also designed for LP as well as gas. The 2 ports on the carb. hat are for heater hose hook up to keep it from frosting up when running LP.
HotRod If I could get enough flow out of a q-jet I would gladly use one. However I am already running a 750 cfm Quick Fuel carb. and its still NA. q-jets from what I have ever read don't flow much over 700 cfm. I've played with q-jets A LOT over the years and love them for daily drivers, but it just wont work in this case.
Old 11-22-2013, 01:31 AM   #6
lurch115
lurch115's Avatar
those are just mock up pictures on a junk motor.
Old 11-22-2013, 11:55 AM   #7
70shortwide
Thats pretty cool I have never seen a setup like that before.
70shortwide is offline   Reply With Quote
Old 11-22-2013, 03:30 PM   #8
Super73
Super73's Avatar
Put an E85 carb on it and don't worry about the 10.5-1 cr as long as you keep boost moderate.
There are LS guys running 12-1 with 15ish lbs of boost on pump grade E85..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
