Old 09-07-2011, 08:23 PM   #1
WETOWM
70 cab frame mounts
Are the frame mounts for the cab the same on 2wd and 4wd frames ??
WETOWM is offline   Reply With Quote
Old 09-07-2011, 11:20 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: 70 cab frame mounts
No, the frame mounts on the 4x4 are thicker.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-08-2011, 12:46 AM   #3
crazy longhorn
Fabricate till you "puke"
To add a little to that, the 3/4 ton 2wd, & the 4x4's have a taller rear cushion...the 1/2 ton 2wd's have the short rear cushion under the cab. My guess ,is that you are looking for the frame brackets? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-08-2011, 08:05 AM   #4
WETOWM
Yes i am looking for the steel brackets that are riveted to the frame for a c10 4x4
Old 09-08-2011, 03:38 PM   #5
crazy longhorn
I think you should also be able to use the brackets, from a 3/4ton 2wd, as the rear cushions are the same as your 4x4. Maybe one of the 4x4 guys will jump in to confirm this.....anyway,BTT. crazyL
