Old 11-29-2011, 08:53 PM   #1
Husker
Husker's Avatar
70 GMC 4x4 ?
I have a 70 GMC4x4 1/2 ton 4 speed tranny not sure of transfer case. The question is: between the transfer case and transmission can the oil move back and forth with out restriction? Otherwise can the oil from the transmission get into the transfer case?
I checked oil in transfer case and it ran out like it was too full and transmission was not full enough. It took about a quart to top off.
Thanks for any help.
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
http://67-72chevytrucks.com/vboard/payments.php
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 11-29-2011, 09:29 PM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: 70 GMC 4x4 ?
I am assuming you have a manual trans. The adaptor between the trans and t case (mostly likely a NP205) does have two seals that keep the fluids separate. Sounds like your seals are shot.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 11-30-2011, 11:34 AM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: 70 GMC 4x4 ?
Same problem occurs with TH350 coupled to a NP205..... seals go bad and trans fluid is pumped into the t-case. To the OP -- it doesn't flow both directions, though.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-30-2011, 12:01 PM   #4
Husker
Husker's Avatar
Re: 70 GMC 4x4 ?
I should be able to drop t-case to get to both seals?
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
Old 11-30-2011, 11:12 PM   #5
JDeere550
JDeere550's Avatar
Re: 70 GMC 4x4 ?
yes sir! ^
1970 C/20 4x4, 350, sm465, np205(She tipped over... total rebuild from the frame up!)
ya gotta keep on keepin' on,
Life's a garden, dig it!
JDeere550 is offline   Reply With Quote
Old 11-30-2011, 11:13 PM   #6
JDeere550
JDeere550's Avatar
Re: 70 GMC 4x4 ?
get a jack or jack stand underneathe that trans to support it though cause the adaptor fromtrans to t-case is what bolts to that crossmember, which i think you'll have to drop down quick
Old 11-30-2011, 11:21 PM   #7
Husker
Husker's Avatar
Re: 70 GMC 4x4 ?
Thanks for help gents! Not sure when I wil lbe able to get to it for sure.
Ron
Member #111
70 4x4 Project
76 Jeep CJ-5
Thomas Jefferson
