Old 09-18-2011, 12:13 PM   #1
kingburnett
Yet another Rear End ID
I need help identifying the rear end on my 1961 K10.
I know that it is not the original.
The cover on the rear has 12 bolts. The Axels have 6 lugs each. I took off the drum and and measured driver side shoes to be 2-inches wide.
The self adjuster is installed wrong.
Other markings on the drum were:Centruy max dia 11.060 Z12006 281 202.
Stamped on the end of the axel was KW 4360.
The number 3896839 with a 1 or I under the 6 is raised on the pumpkin housing on the front passenger side. There is a GM84 marking on the front driver side.
There is a date code looks to be 8Z1 ? Looks to be a GM Corporate 12-Bolt. I have no clue of the year. I need to fix the brakes, especially the parking brakes. Looks like the cables for the park brakes are all wrong for a K10. Probably came off of a C10.
Thanks for the help.
I like More's Law 'If more is better, then too much is just right.'
http://s1238.photobucket.com/albums/...20chevy%20k10/
1971 Chevelle - sbc 350 TH350
1961 K10 - sbc 400 4 spd M/T short stepside
kingburnett is offline   Reply With Quote
