Old 08-29-2011, 12:21 AM   #1
Billybob13
Billybob13's Avatar
prerunner conversion
ok guys need a little help on my parts quest. the motor swap from hell is near its end and ive come to the decision of turning my 83 into a prerunner so i need help on finding long travel suspension for front, fiberglass bubble out fenders, and locking rear axle if im missing anything(other then roll cage ass.) let me know and any info on where to get these pre built if i can but if i have to have custom made oh well thanks.
'83 chevy c-10 scottsdale 400 cid 2wd "chelsea"
Billybob13 is offline   Reply With Quote
Old 08-30-2011, 10:57 PM   #2
Prerunner1982
Prerunner1982's Avatar
Re: prerunner conversion
The suspension will have to be custom if you want long travel. Only thing available are coils, spacers, and may still A arms. The stock design does not allow long travel. There are/were 'glass fenders available. Check out Hanneman Fiberglass and Glassworks Unlimited. The locking rear axle should be easy... you can get spools/lockers are any 4x4 shop/retailer.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 08-31-2011, 11:34 PM   #3
Billybob13
Billybob13's Avatar
ok thanks
Old 09-01-2011, 10:35 PM   #4
Prerunner1982
I have a Square body prerunner pic thread around here somewhere if you want some ideas/motivation.
http://67-72chevytrucks.com/vboard/s...ad.php?t=31852
Jon
Oklahoma Roll Call
Old 10-01-2011, 07:49 PM   #5
Billybob13
Billybob13's Avatar
nice trucks thanks for link
Old 10-02-2011, 10:04 PM   #6
orbot
orbot's Avatar
You can take the i beams from an older ford truck and adapt the to the chevy frame, you will need control arms and the crossover steering set up, shocks/coil overs, limit straps, heims, longer brake lines, lots of fab work.
check out this place.
dezertrangers.com
lots of info.
orbot is offline   Reply With Quote
Old 10-03-2011, 01:08 AM   #7
Billybob13
Billybob13's Avatar
so id need to raid a ford fof long travel
Old 10-03-2011, 02:01 AM   #8
project 67 sub
project 67 sub's Avatar
that will probably be the cheapest and easiest way of doing it
project 67 sub is offline   Reply With Quote
Old 10-03-2011, 02:57 PM   #9
orbot
orbot's Avatar
Yep..
