1985 k10 turn signal hazard problem
Help my sons 1985 k10 truck has a problem when he put on the right or left turn signal on the flashers come on, also when he steps on the brake the front and back parking lights come on. please help...........
Thanks |
Re: 1985 k10 turn signal hazard problem
Check the towing package, and check if the hazzards are stuck on
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great 1979 Chevy 1/2 ton long bed diesel 1974 Chevy crew cab short bed 3/4 ton 4x4 project 1991 Chevy suburban 2wd 1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo 1961 Chevy pickup 1/2 ton 2wd 1975 gmc crew cab short bed 2wd |
This, and also check to see if the hazard switch is pushed halfway in or is jumping connections inside the steering column.
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
if you haven't found it yet, this is what i would try next.. remove the bulbs, remove the fuses and flasher relay.. then check for crosses with a meter.. two wires pinched together working like a splice.. if you do not find a cross, test for a short between any wire and ground..
most common seems to be wires pinched.. |
